Installation & Licensing
problem wit activation (error code 400)
2 REPLIES 2
bntadmin
772 Views, 2 Replies
I have a problem with activation autodesk autocad lt 2015
the problem is that:
When I clicked on "Activate" and next "Continue" the next screen was "Processing Error"
Your online activation request has returned an error (400) which is not allowing your request to be processed using our automated systems.
 Click the "Use another method" link below to complete the necessary forms and submit your request to the local Autodesk Business Center for your area. A Customer Service Representative will respond within the next 2 business days.
Thanks.
2 REPLIES 2
jeffrey.sin
in reply to: bntadmin
Hi @bntadmin
I was not able to find or associate any serial number to your email address. In any case, for licensing assistance such as the error you are getting, it would be best to contact our Registration and Activation team directly:
1. Kindly go to http://knowledge.autodesk.com/contactus
2. Select "Activation & Registration"
3. Select "Activating a Product"
4. Select "Activation Codes and Request Codes"
5. Click on "I Still Need Help"
You may then engage with the team either via chat or by submitting a support request. Let us know if you have any other questions or would need further assistance.
Jeffrey Sin
Autodesk Customer Support
bntadmin
in reply to: jeffrey.sin
I sent an e-mail to the support team umuratam@advmakine.com.tr behalf. I hope you find a solution.
Administrator Productivity
