Installation & Licensing
Problem w 3ds max 2013 activate - the software license check out ... Error 25
7 REPLIES 7
Message 1 of 8
6656 Views, 7 Replies
I downloaded and installed 3dsmax 2013 with a valid serial number and product key. I had previously installed Maya 2012 and that program is working fine on the same computer.
The install of 3ds is successful, but when I try to run the program it tells me "The software license check out failed. Error 25".
I'm running Windows 7 home premium on an i3 laptop. Your help would be very much appreciated.
7 REPLIES 7
Message 2 of 8
philip.s
aldosa,
Have you tried looking at the solution listed here?
Message 3 of 8
Certainly. there's no "programdata" directory on my system. Regarding the "all users" folder, windows 7 does not use such a folder. I looked for .pit files and found several, but not in the places indicated. Since I have Maya working I don't want to mess that up by erasing the wrong file.
I have Maya 2012 and 3ds 2013 running side by side, is that simply not supported?
A step by step would help me out a lot. I'm sure I'm not the only one with this problem. No reply from autodesk support.
Thank you.
Message 4 of 8
DarrenP
the program data folder is a hidden windows folder
http://www.sevenforums.com/tutorials/394-hidden-files-folders-show-hide.html
DarrenP
Message 5 of 8
Actually I did get a response from support to this article:
http://forums.autodesk.com/t5/Installation-Licensing/The-software-license-check-out-failed-Error-25/...
which was equally unhelpful since none of the reference files are in my system. Thanks
Message 6 of 8
in reply to: DarrenP
Thanks. I just saw this. I'll give it a try.
Message 7 of 8
Thank you for that tip. Removed the files. Same behavior on program startup.
Message 8 of 8
Deleting the files reset my maya license but didn't affect the 3ds program. Bummer.
Administrator Productivity
