Hi!
When the program starts the splash screen flashes and the program shutsdown. I found the following link: http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCAD...
and it seems to be a problem with the licensing service. But when i look in services the service: FLEXnet Licensing Service is missing.
And when I look in my computer in the following location: "Vista/Windows 7:
C:\ProgramData\FLEXnet\adskflex_*_tsf.data" then there is no FLEXnet folder under ProgramData.
Do you need to install that separatly when you install the program?
Is your AutoCAD a network or a standalone license? The flexnet folder is only there if it is a standalone install. Also, what operating system are you running because on windows XP it's in a different location.
