Installation & Licensing
New Member
gjmichie
Message 1 of 2 (254 Views)
Problem running Autocad LT 2013
254 Views, 1 Replies
11-20-2012 01:32 AM
I have setup a deployment package for Autocad LT 2013.
If I run the shortcut which runs the setup.exe with an ini file it all installs and works fine.
I need to install all pre-reqs and components seperately as that is the company policy.
I am installing all pre-reqs.
Once I have installed Autocad LT 2013 and the language packs when running Autocad I get the following error:
The pre-installed product installation may have failed due to corrupted files. Please reinstall the product using the supplied disks.
I have also noticed that when you try to uninstall Autocad LT 2013 it comes up with an error that it may have already been uninstalled would you like to remove it from programs and features.
I am using Windows 7 x64.
Any help would be good.
Product Support
david.lau
Message 2 of 2 (230 Views)
Re: Problem running Autocad LT 2013
11-21-2012 05:18 AM in reply to: gjmichie
