Installation & Licensing
Member
muhammad.alfian
Message 1 of 4 (294 Views)
Problem network licensing Autodesk PDSU 2013
294 Views, 3 Replies
06-26-2013 12:51 AM
I have some trouble with PDSU 2013 network licensing, some product can run normal with my network license. But I can't running another product in Autodesk Product Design Suite Ultimate 2013 like Naviswork manage, Mudbox, Sketchbook, 3Dmax, Alias design, ACAD Electrical. When I tried to start up I have error message:
A valid license could not be obtained by network license manager.
If you still unable to access a license, contact your system administrator.
Error [-4.132.0]
Please Help!
Darin.Green
Message 2 of 4 (282 Views)
Re: Problem network licensing Autodesk PDSU 2013
06-26-2013 05:03 AM in reply to: muhammad.alfian
How many licenses do you have of the suite?
Are you trying to work in two Autodesk products at the same time?
If you only have one license and you're trying to open two product side by side, you will encounter this issue. You'll need to close out of one app and open the other.
Darin Green
Synergis Technologies
If this resolve your issue/question, give Kudos or Accept as Solution...
Member
muhammad.alfian
Message 3 of 4 (251 Views)
06-28-2013 02:18 AM in reply to: Darin.Green
There is 2 seats for the suite, and just 2 client use it.
TravisNave
Message 4 of 4 (244 Views)
06-28-2013 07:57 AM in reply to: muhammad.alfian
The -4 error simply means that you are out of licenses.  So apparently, there are none available.  You can do a status enquiry from the LMTOOLS server status tab and see who has the licenses checked out.
