Installation & Licensing
Problem Launching Industrial Design Suite without administrator rights
2 REPLIES 2
Logos_Atum
196 Views, 2 Replies
Hello There, i have a question concerning the priviliges needed for Industrial Design Suite to run correctly,
as we encountered problems when running it without administrator rights. Which priviliges does an user need to run it without errors?
Best wishes
Daniel Thringer
Dogs aren´t flammable.
2 REPLIES 2
TravisNave
in reply to: Logos_Atum
It is typically recommended that users have local administrator or power user rights on their machines.  This is not to be confused with domain admin rights.  Local administrator privilege does not circumvent domain OE policies, it simply elevates the privileges needed to access additional resources on the client machine.  There is no reason not to give your engineers access to their machines.  Any additinal domain policy GPO will still be enforced and no additional enterprise rights are extended to local administrators on your domain.  If the program behaves with the appropriate elevated rights, then assign those rights as needed.
Autodesk Forums:
Logos_Atum
in reply to: TravisNave
Thank you very much - this will avoid problems in the future.
I am thankful for the administrator privileges this "error" gave me 😄
Administrator Productivity
