Installation & Licensing
Problem installing student version of 3ds max 2014
3 REPLIES 3
373 Views, 3 Replies
Help, I need urgently 3ds max for some exercises and I am unable to install it..
I have downloaded the student version of 2014 edition and every time I try to install it it shows errors in every procedure from the beginning of the installation process and it immediatelly says that installation is complete but everything have failed to be installed!!! I can't figure out what is going on, I have tried everything and several times.. do you have any suggestions? I have windows 7 64 bit, 4 GB Ram, intel core i5.. Thanks in advance..
3 REPLIES 3
here is the log file from the trial version I tried to download and had the same results..
2014/4/13:04:10:17 user USER-PC === Setup started on USER-PC by user ===
2014/4/13:04:10:17 user USER-PC Path_Length: 151
2014/4/13:04:10:17 user USER-PC Current Directory C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm
2014/4/13:04:10:17 user USER-PC Launch
2014/4/13:04:10:17 user USER-PC CommandLine
2014/4/13:04:10:18 user USER-PC Path_Length: 151
2014/4/13:04:10:18 user USER-PC Current Directory C:\Users\user\AppData\Local\Temp\_AI5936.tmp
2014/4/13:04:10:31 user USER-PC === Setup ended ===
2014/4/13:04:10:22 user USER-PC === Setup started on USER-PC by user ===
2014/4/13:04:10:22 user USER-PC Path_Length: 151
2014/4/13:04:10:22 user USER-PC Current Directory C:\Users\user\AppData\Local\Temp\_AI5936.tmp
2014/4/13:04:10:22 user USER-PC Launch
2014/4/13:04:10:31 user USER-PC PageOpen LaunchDialog
2014/4/13:04:10:41 user USER-PC PageOpen LicenseDialog
2014/4/13:04:10:41 user USER-PC PageOpen ProductSelectionDialog2
2014/4/13:04:12:47 user USER-PC === Setup ended ===
2014/4/13:04:21:03 user USER-PC === Setup started on USER-PC by user ===
2014/4/13:04:21:03 user USER-PC Path_Length: 151
2014/4/13:04:21:03 user USER-PC Current Directory C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm
2014/4/13:04:21:03 user USER-PC Launch
2014/4/13:04:21:03 user USER-PC CommandLine
2014/4/13:04:21:03 user USER-PC Current Directory C:\Users\user\AppData\Local\Temp\_AI3487.tmp
2014/4/13:04:21:23 user USER-PC === Setup ended ===
2014/4/13:04:21:08 user USER-PC === Setup started on USER-PC by user ===
2014/4/13:04:21:08 user USER-PC Path_Length: 151
2014/4/13:04:21:08 user USER-PC Current Directory C:\Users\user\AppData\Local\Temp\_AI3487.tmp
2014/4/13:04:21:08 user USER-PC Launch
2014/4/13:04:21:23 user USER-PC PageOpen LaunchDialog
2014/4/13:04:28:22 user USER-PC PageOpen LicenseDialog
2014/4/13:04:29:24 user USER-PC PageOpen LaunchDialog
2014/4/13:04:29:35 user USER-PC PageOpen ProductInfoDialog
2014/4/13:04:29:56 user USER-PC PageOpen ProductSelectionDialog2
2014/4/13:04:30:09 user USER-PC PageOpen FullProgressDialog
2014/4/13:04:30:09 user USER-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\user\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/4/13:04:30:10 user USER-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
2014/4/13:06:38:36 user USER-PC === Setup started on USER-PC by user ===
2014/4/13:06:38:36 user USER-PC Path_Length: 151
2014/4/13:06:38:36 user USER-PC Current Directory C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_wi_en-US
2014/4/13:06:38:36 user USER-PC Launch
2014/4/13:06:38:36 user USER-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_wi_en-US_... /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/4/13:06:38:36 user USER-PC Current Directory C:\Users\user\AppData\Local\Temp\_AIEC72.tmp
2014/4/13:06:39:28 user USER-PC === Setup ended ===
2014/4/13:06:38:37 user USER-PC === Setup started on USER-PC by user ===
2014/4/13:06:38:37 user USER-PC Path_Length: 151
2014/4/13:06:38:37 user USER-PC Current Directory C:\Users\user\AppData\Local\Temp\_AIEC72.tmp
2014/4/13:06:38:37 user USER-PC Launch
2014/4/13:06:39:28 user USER-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/{CE0ABC82-BD3C-4F3D-9370-6CEBA82D6532}/SETUP_x64...
2014/4/13:06:39:28 user USER-PC PageOpen LaunchDialog
2014/4/13:06:39:34 user USER-PC PageOpen LicenseDialog
2014/4/13:06:39:34 user USER-PC PageOpen ProductInfoDialog
2014/4/13:06:39:39 user USER-PC PageOpen ProductSelectionDialog2
2014/4/13:06:40:09 user USER-PC PageOpen FullProgressDialog
2014/4/13:06:40:09 user USER-PC Download Skipped VCREDIST2005SP1ATLX86 http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/{CE0ABC82-BD3C-4F3D-9370-6CEBA82D6532}/VCREDIST2...
2014/4/13:06:40:09 user USER-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2014\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\user\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/4/13:06:40:25 user USER-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
I have the same problem Smiley Frustrated
Have reinstalled visual c + + 2005 but nothing has changed
I have tried other types of installation and it did not work
Sorry for my bad english,i'm Brazilian Smiley Sad
"C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Linke\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/4/13:04:57:02 Linke LINKE-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603"
Me too.. I installed visual c++ 2010 but nothing happened 😕
Administrator Productivity
