Installation & Licensing
New Member
monteig3
Message 1 of 8 (1,087 Views)
Problem installing Revit 2014 (student version)
1087 Views, 7 Replies
03-02-2014 08:15 PM
Hello Guys,
I had a problem in my laptop and I had to reinstall my windows.
Now, I am facing a problem on the installation of Revit 2014 (student version).
I have been trying too many things attempting to fix this problem, I have no luck. :mansad:
I uninstalled so many times the "Microsoft Microsoft Visual C++" 2005 and all other versions 2008/2010. through Panel Control and also another tool called "dotnetfx_cleanup_tool" etc...I dont know what to do.
I had a similar issue when I was installing Autocad Architecture 2014 but I solved removing Microsoft .net 4.5 and installiing 4.0 version.
If someone could clarify what is going on and how to solve it, I appreciate.
I have no idols. I admire work, dedication and competence. - Ayrton Senna
Please ensure the following has been done:
1. Computer meets the minimum requirements
2. UAC off
3. Firewall off
4. Anti-Virus off
5. Administrator rights
6. Clear the temp folder
7. Make sure you have enough disc space 60 Gigs at least
8. Make sure the OS is up to date
9. Reinstall C++ redistributable
10. Reinstall .Net Framework
11. Copy the content of the installation media to the C drive. Preferably on the root of the C drive to negate the problem of filenames becoming too long
12. Make sure short file name creation has been enabled HKEY_LOCAL_MACHINE\SYSTEM\
CurrentControlSet\Control\FileSystem Set NtfsDisable8dot3NameCreation to a value of 0
13. Create a new Windows user with full admin rights
14. If the computer is on a domain remove it from the network completely for the duration of installation
Let me know if there is a step you dont know how to do. If that still does not work, please let me know so I could continue to trouble shoot your issue. Have you tried downloading a trial version and licensing it afterwards?
JoAnn_Hogan
Message 2 of 8 (1,059 Views)
Re: Problem installing Revit 2014 (student version)
03-03-2014 12:41 AM in reply to: monteig3
2. UAC off
3. Firewall off
4. Anti-Virus off
If this post solved your issue please mark as solved and Kudos are always welcome =)
Jo - Ann
Twitter: @JoAnn_Hogan
AutoCAD Certified Professional 2015 / Inventor Certified Professional 2015
New Member
monteig3
Message 3 of 8 (1,047 Views)
03-03-2014 04:42 AM in reply to: JoAnn_Hogan
Hello Joann,
I really thank you for the message. I solved my problem after checking your list.
Anti-Virus Off
UAC Off
Cleaned temp folder
I needed to update my OS as I had reinstalled the system.
and I changed the value on step 12 to "0"
Done!!!
I appreciated your attention.
Now I can work quietly on my university projects!
Have a good day,
Guilherme Macedo Monteiro
JoAnn_Hogan
Message 4 of 8 (1,042 Views)
03-03-2014 04:59 AM in reply to: monteig3
Its a pleasure. I am glad I could help. =)
Jo - Ann
Active Member
mohuk2007
Message 5 of 8 (1,037 Views)
03-03-2014 05:57 AM in reply to: monteig3
I am trying to install the educational version of Revit 2014,
It keeps saying communication failure,
I have tried it over a 100 times, something most be wrong.
Kindly advise please.
JoAnn_Hogan
Message 6 of 8 (1,032 Views)
03-03-2014 06:15 AM in reply to: mohuk2007
Hi Mohuk,
Please post this as a new issue. It will help us to see if it is resolved or not.
Kindy follow this link to create a new issue: http://forums.autodesk.com/t5/forums/postpage/board-id/24
Jo - Ann
New Member
jric164
Message 7 of 8 (680 Views)
05-19-2014 12:52 AM in reply to: monteig3
How do you do numbers 11 and 12?
Member
knseo
Message 8 of 8 (674 Views)
05-19-2014 02:44 AM in reply to: monteig3
