Installation & Licensing
New Member
rfitzwilliam1
Message 1 of 2 (150 Views)
Problem installing Inventor Pro 2012
150 Views, 1 Replies
12-05-2012 06:21 PM
I have tried to install 3 times and get the same error issue..Computer: Windows 7,,64bit, I also have Inventor 2013 also loaded-used brower download.
Design Review module won't load....
2012/12/5:20:07:35 mom HOME-PC Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\mom\AppData\Local\Temp\vcredist_x86_2010.log
2012/12/5:20:07:39 mom HOME-PC Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
Active Member
_AdamN_
Message 2 of 2 (143 Views)
Re: Problem installing Inventor Pro 2012
12-05-2012 06:51 PM in reply to: rfitzwilliam1
Pleae refer to the Autodesk Discussion at the link below..
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
TravisNave has provided a couple solutions that quite often remedy this error.
_____________________________________________________________
KarelCAD Application Support Specialist
