I am currently trying to install AutoCAD MEP 2015 on my laptop which is using Widows 8.1 OS system and
I keep getting installation failed message. Has anyone experienced the same problem before? I included
a copy of the error report but I cannot really decipher what is the error. Any help would be greatly
apprecIated.
Note : is installing the student free trial 64-bit program
JDL
Solved by dembkod. Go to Solution.
Hello. You are conflicting with the Microsoft C++ installers. Uninstall the Microsoft C++ from the machine before you run the installer. You will have multiple entries. I would pull them all out.
After this you will likely install just fine.
At this stage, if not, go to the C:\autodesk\ install folder and open the setup.ini file
Search and replace all PREREQ entries with #PREREQ and save the file. Then run the installer.
Thank you for taking part in our community!
