Installation & Licensing
Problem installing Autocad for Mac
20 REPLIES 20
Message 1 of 21
tah76
5740 Views, 20 Replies
When I go to download the new student version, The installer.dmg mounts, but when I click on the Akamai icon, I get an error message:
Install Error
Failed to install client: Disk I/O Failure. Failed in writing contents of file /Applications/Akamai/client.ini to disk. Aborting installation.
I'm installing it on my personal computer, on my home network.
20 REPLIES 20
Message 2 of 21
hashim.mundol
in reply to: tah76
Are you running this as admin user ? this is the downlload manager from akamai. which helps in faster download of the actual Autocad Package.
Please try as admin user. it should work.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
Autodesk, Inc.
Message 3 of 21
mritchey1
in reply to: tah76
I am having the same problem as well. I am the Admin on the computer, the only user on the computer. Whenever I try to open the Akamai link, I get the following error message.
Install Error
Any help would be great.
Message 4 of 21
marial7
in reply to: tah76
I am the only user on my computer and I have the exact same problem! Dying to get AutoCAD on my Mac; any advice is appreciated!
Message 5 of 21
hashim.mundol
in reply to: mritchey1
This error is from Akamai download manager,
you could try to create an admin user and try.
If you still have issue you could try to download the software using a different browser
or
try to get the download manager from the Akamai Demo page(you can cancel the sample file download). once this is installed,
http://client.akamai.com/demos/csd-BasicDownload.html
 you can try to download the Auotcad Mac software from Autodesk site, which should use the latest download manager installed using Demopage.
Hashim Mundol
Autodesk, Inc.
Message 6 of 21
porter843
OK, here is how to do this and make it work.
In your profile open the Utilities Folder > Directory Utility.  With Directory Utility Open on the menu line click Edit then check Enable Root User.
Click the apple and log out user.  When the login screen shows up there will be your normal user and Other.
Click Other, type root as the user and the root password you setup when you set up your Mac.  The same password you use when you use the SUDO command.
Fill out the application for the software in that profile, the Akamai Loader loads and the AutoDesk AutoCAD for Mac DMG starts downloading.  Select the save location as your desktop of your normal profile and select save.  Log out of root, log back in as your normal profile and the dmg file is ready to load.
I have a MacBookPro 17" with OSX 10.5.8, I know there are subtle differences in how to enable the root user but the general idea is there.
I installed AutoCAD for Mac in my normal profile and it works well, same drawing toolbox, same settings, my old drawings open fine.  This is a fine application especially for first gen on the Mac.
Message 7 of 21
mritchey1
in reply to: porter843
For me, I found a solution. I don't know if it was just added, but it works, at least for the Education download.
If you select the AutoCad 2011 for Mac Download, it takes you to the page that has the download button, serial number, and product key on it. Instead of hitting the download button, there is a sentence just below it:
"If you are having trouble with your download, please click here to download using your browser."
All I had to do was click on the word "here" and it started to download the actual AutoCad 2011 for Mac disk mount image, instead of the Akamai dmg. When that was downloading, I installed it like I would any other app, and AutoCad runs great for me.
Message 8 of 21
patrickbanks1229
in reply to: tah76
Same problem here except after getting the error message a few times, I checked for software updates to the OS.  There was an update for Java.  Now I don't get the error message - NOTHING happens.  At least the error message told me it tried to work.
It's ridiculous that I can't download the trial because of some defective third party software!   Can't Autodesk make its own disk image?  Maybe I should wait for the next release of Autocad for Mac, if the installer doesn't even work, how much can I expect from the software itself???
Message 9 of 21
hashim.mundol
in reply to: tah76
there are some other suggestions in these forums
update Java to JavaForMacOSX10.4Release9
http://forums.autodesk.com/t5/AutoCAD-for-Mac/Installer-Crashes/m-p/2798486/highlight/true#M39
or give permissions to /Applications folder.
http://forums.autodesk.com/t5/AutoCAD-for-Mac/AutoCAD-2011-for-Mac-system-requirements/td-p/2798020/...
Hashim Mundol
Autodesk, Inc.
Message 10 of 21
porter843
in reply to: tah76
There are ways to make it work, see above.  This is a really nice product.  I am not an Autodesk employee and have been waiting for AutoCAD for Mac for years.  I got this installed and love it.  Don't wait for future releases.  The thing that is failing is not the AutoCAD installer, it is the Akamai downloader.  Once I logged into my root account everything worked fine with the downloader, then I logged back into my regular account to load AutoCAD.
Don't give up, the AutoCAD software is worth not having to load Windows in bootcamp or have a separate computer for AutoCAD.
Message 11 of 21
darekhyc
in reply to: tah76
I have a different problem. Trying to start trial version I downloaded and installed from Autodesk side I can see Autocad 2011 starting page saying “loading” and then nothing happens. I can see no Autocad. I installed id twice and there was no result at all. I was trying it on both MacBook Pro 2.66 Intel Core i7 (8 GB ram) and Mac Pro 2x3.2 Quad Core Xeon (6 GB ram) both with OS X 10.6.4 and I have the same problem. Is there a simple solution to this problem?
Message 12 of 21
vago001
in reply to: darekhyc
I have the same problem, anyone knows where is the mistake?
Message 13 of 21
vago001
in reply to: vago001
i download java update but nothing change.
Message 14 of 21
przemoriginal
I had the same problem but it's simple to fix it. You're probably person which main language is different than english or german. My main language is polish. To open AutoCAD You have to change Your main language for instance english and restart Your Mac. Than You can easily run AutoCAD. Good luck!
Message 15 of 21
darekhyc
THX przemoriginal it was simple. Now it works. I wonder why Autodesk guys can't fix such a simple problem. Maby they don't plan to go international with this product 🙂 Now I will have a chance to check what else they .....
Message 16 of 21
przemoriginal
It's nice to be helpful:) I don't know why this problem exist. At least they know about it: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15860222&linkID=15839490 All we can do is wait for update. It would be great if they translate AutoCAD for Mac to another languages:)
Message 17 of 21
vago001
thanks!!!
Message 18 of 21
vago001
noooo!!! the problem still remains, i
Message 19 of 21
cool91omar
in reply to: tah76
i have the same problem that all you people i install the Autocad but when i tried to open it a loading windows pop up and never dissapear. i ve read the post that said to change the main language but my main language is in english sitll dont work, plz i need some solution dont know what to do. i can draw and open flies but the windows still in the middle of the screen so i cant work 😞
i attach a screenshot of the problem
Message 20 of 21
hashim.mundol
in reply to: cool91omar
This should fix the splash screen issue
http://usa.autodesk.com/getdoc/id=TS15916540
there is update1 which has more fixes
http://usa.autodesk.com/getdoc/id=DL16105699
Hashim Mundol
Autodesk, Inc.
Administrator Productivity
