Installation & Licensing
problem installing ACLT 2012
4 REPLIES 4
aaron
745 Views, 4 Replies
I tried installing about 6 times, all have failed. I searched this board and found a solution that I (in theory) already did, still no help. I found one reference to media files from ACLT 2011, but I am installing from 2010. The errors are 1603 and 1619. I am installing on WinXP Pro, SP2.
The log is:
2011/10/31:11:41:42 Aaron LIGHTING Launch
2011/10/31:11:43:27 Aaron LIGHTING PageOpen LaunchDialog
2011/10/31:11:44:51 Aaron LIGHTING PageOpen LicenseDialog
2011/10/31:11:45:10 Aaron LIGHTING PageOpen ProductInfoDialog
2011/10/31:11:45:50 Aaron LIGHTING PageOpen ProductSelectionDialog2
2011/10/31:11:46:03 Aaron LIGHTING PageOpen FullProgressDialog
2011/10/31:11:46:04 Aaron LIGHTING Installing DirectX Runtime: C:\Autodesk\AutoCAD_LT_2012_Multilingual_WIN_32bit\3rdParty\DirectX\DXSETUP.exe /silent
2011/10/31:11:46:54 Aaron LIGHTING Install DirectX Runtime Succeeded
2011/10/31:11:46:54 Aaron LIGHTING Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_LT_2012_Multilingual_WIN_32bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/10/31:11:47:46 Aaron LIGHTING Install Autodesk Material Library 2012 Succeeded
2011/10/31:11:47:46 Aaron LIGHTING Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_LT_2012_Multilingual_WIN_32bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/10/31:11:48:52 Aaron LIGHTING Install Autodesk Material Library 2012 - Low Resolution Succeeded
2011/10/31:11:48:52 Aaron LIGHTING Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_LT_2012_Multilingual_WIN_32bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/10/31:11:49:19 Aaron LIGHTING Install Autodesk Content Service Succeeded
2011/10/31:11:49:20 Aaron LIGHTING Installing AutoCAD LT® 2012: TRANSFORMS="C:\Autodesk\AutoCAD_LT_2012_Multilingual_WIN_32bit\x86\en-us\acadlt\acadlt.mst;C:\DOCUME~1\AARON~1.AIR\LOCALS~1\Temp\_AI8.tmp\x86\acadlt\acadlt-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_LT_2012_Multilingual_WIN_32bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD LT 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/10/31:11:57:56 Aaron LIGHTING Install AutoCAD LT® 2012 Failed Installation aborted, Result=1603
2011/10/31:11:58:34 Aaron LIGHTING Rollback Autodesk Content Service Succeeded
2011/10/31:11:59:44 Aaron LIGHTING Rollback Autodesk Material Library 2012 - Low Resolution Succeeded
2011/10/31:12:01:02 Aaron LIGHTING Rollback Autodesk Material Library 2012 Succeeded
2011/10/31:12:01:03 Aaron LIGHTING Rollback DirectX Runtime Failed Failure is ignored, Result=1619
4 REPLIES 4
aaron
in reply to: aaron
I am having the same problem. I am moving from LT2010, not LT 2011. i have installed DirectX as noted, rebooted, re-attempted to install ACLT12.
Your answers to the previous posts on the same topic were pretty weak, hopefully you can provide a solution.
Charles_Shade
in reply to: aaron
First thing would be to post here:
Installation and Licensing Forum:
http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
Some good people over there at troubleshooting installs.
As a SWAG: I too experienced an install issue that had to do with a language pack. This required me to need to go to the registry and delete a particular entry to be able to proceed with the install. The SWAG is that in the rollback portion of your info the Launguage Pack or Multilingual is not rolled back.
1603 is a Direct-X failure. Your last line seems to indicate thus
1619 does not return a result
aaron
in reply to: Charles_Shade
Thanks, Charles.I appreciate your help.
I've re-installed the DirectX and rebooted, plus checked the licensing baord as you suggested. What I'm coming up with is that many people are having this or similar problems, and unfortunately, Autodesk's moderators have not supplied any useful answers. I'll keep muddling through and try a few more things, but I suspect this is the last product I buy from Autodesk. I find their lack of support and customer service to be beyond subpar.
Charles_Shade
in reply to: aaron
Sorry you are having difficulty with Autodesk.
Being the purhcaser of a new product you should be able to get direct help from Autodesk to get the prgram working.
Up and Ready Support  (It aint easy to find)
There are two common problems that I listed above. The third can be .NET 4.0 Framework being corrupt. AutoCAD can choke on this when other programs do not. You may find that you need to uninstall the current .NET 4.0 Framework that you have and let the AutoCAD install reinstall this.
Did I ask if you removed the Direct X from the CPU prior to the LT install?
If you do not know - This is peer support with limited Autodesk direct involvement.
You may want to seek out a poster named Travisnave who frequents the Install Forum - He' the Dean of that Forum. (You've not conversed with our Dean yet. Smiley Wink)
Administrator Productivity
