Installation & Licensing
problem in the installation of AutoCad 2014
1 REPLY 1
noor.issa94
312 Views, 1 Reply
Hen ever i try to downlad autocad it tells me the the instlation is complete. some product fail to install.
Can someone please tell me how to fix this problem ,, I really need autocad 2014 ASAP fo a college project.
Here is the log file that was saved:
2014/4/5:09:13:56 speac_000 NOOR === Setup started on NOOR by speac_000 ===
2014/4/5:09:13:56 speac_000 NOOR Path_Length: 155
2014/4/5:09:13:56 speac_000 NOOR Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2014/4/5:09:13:56 speac_000 NOOR Launch
2014/4/5:09:13:56 speac_000 NOOR CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/AutoCAD_2014_English_Win_32_64bit_wi_en-us_Setu... /SN 900-32044837 /PK 001F1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/4/5:09:13:56 speac_000 NOOR Current Directory C:\Users\SPEAC_~1\AppData\Local\Temp\_AI2AFE.tmp
2014/4/5:09:14:01 speac_000 NOOR === Setup ended ===
2014/4/5:09:13:57 speac_000 NOOR === Setup started on NOOR by speac_000 ===
2014/4/5:09:13:57 speac_000 NOOR Path_Length: 155
2014/4/5:09:13:57 speac_000 NOOR Current Directory C:\Users\SPEAC_~1\AppData\Local\Temp\_AI2AFE.tmp
2014/4/5:09:13:57 speac_000 NOOR Launch
2014/4/5:09:13:58 speac_000 NOOR Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/SETUP_x6...
2014/4/5:09:14:01 speac_000 NOOR Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\SPEAC_~1\AppData\Local\Temp\_AI2AFE.tmp\Setup\AcSetup.dll
2014/4/5:09:14:01 speac_000 NOOR Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/4/5:09:14:01 speac_000 NOOR PageOpen LaunchDialog
2014/4/5:09:17:57 speac_000 NOOR PageOpen LicenseDialog
2014/4/5:09:17:57 speac_000 NOOR PageOpen ProductInfoDialog
2014/4/5:09:17:57 speac_000 NOOR PageOpen ProductSelectionDialog2
2014/4/5:09:18:05 speac_000 NOOR PageOpen FullProgressDialog
2014/4/5:09:18:05 speac_000 NOOR Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/DIRECTX....
2014/4/5:09:18:05 speac_000 NOOR Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/4/5:09:18:19 speac_000 NOOR Install DirectX Runtime Succeeded
2014/4/5:09:18:20 speac_000 NOOR Installing FARO LS 5.1.0.30630 (64bit): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/5:09:18:41 speac_000 NOOR Install FARO LS 5.1.0.30630 (64bit) Succeeded
2014/4/5:09:18:41 speac_000 NOOR Download Skipped CM http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/CM.tar.l...
2014/4/5:09:18:41 speac_000 NOOR Installing Autodesk Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/5:09:19:10 speac_000 NOOR Install Autodesk Material Library 2014 Succeeded
2014/4/5:09:19:10 speac_000 NOOR Download Skipped CMILB http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/CMILB.ta...
2014/4/5:09:19:10 speac_000 NOOR Installing Autodesk Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/5:09:19:38 speac_000 NOOR Install Autodesk Material Library 2014 - Base Image Library Succeeded
2014/4/5:09:19:40 speac_000 NOOR Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2014\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),.NET Framework Runtime 4.0,;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/5:09:19:50 speac_000 NOOR Install Autodesk Content Service Succeeded
2014/4/5:09:19:50 speac_000 NOOR Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/5:09:19:57 speac_000 NOOR Install Autodesk Content Service Language Pack Succeeded
2014/4/5:09:19:58 speac_000 NOOR Download Play ACAD http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/ACAD_x64...
2014/4/5:09:32:41 speac_000 NOOR Download Aborted ACAD http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/ACAD_x64...
2014/4/5:09:32:41 speac_000 NOOR Install Autodesk® AutoCAD® 2014 Failed Download Failed, Installation aborted, Result=1603
2014/4/5:09:32:53 speac_000 NOOR Rollback Autodesk Content Service Language Pack Succeeded
2014/4/5:09:33:53 speac_000 NOOR Rollback Autodesk Content Service Succeeded
2014/4/5:09:34:35 speac_000 NOOR Rollback Autodesk Material Library 2014 - Base Image Library Succeeded
2014/4/5:09:35:32 speac_000 NOOR Rollback Autodesk Material Library 2014 Succeeded
2014/4/5:09:39:39 speac_000 NOOR Rollback FARO LS 5.1.0.30630 (64bit) Succeeded
2014/4/5:09:39:39 speac_000 NOOR Rollback DirectX Runtime Failed Failure is ignored, Result=1619
Tags (3)
1 REPLY 1
pendean
in reply to: noor.issa94
Search around here or in any Autidesk page or through your favorite search engine for error 1603 and error 1619: there are many answers already posted.
Administrator Productivity
