I have been communicating with the support service team for over 2 weeks trying to install Autodesk Revit 2013 or 2014 on to my laptop. I get the following error message.
C:\Users\Sai Keerthana\AppData\Local\Temp\_AI64BD.tmp\Setup.exe/s D:\AutoDesk Revit 2013\Autodesk_Revit_2013_English_Win_32bit-64bit\ /temp C:\Users\Sai Keerthana\AppData\Local\Temp\_AI64BD.tmp\ /secondRun /Lang en-us /FirstRunThreadld32
As suggested by team have deleted all files of autodesk, then using ccleaner removed all improperly installed file.
Continued to receive same error message.
As suggested then deleted the 3 registry keys, then re-downloaded the Autodesk Revit software, again the same error message appears. As the error message is same has not send the screen shot here.
Some friends informed that if a separate profile is created and then autodesk is installed in the new profile this problem could be solved. Accordingly I created a separate profile in my laptop and then tried downloading the Revit 2013 software. Again the same problem is seen.
1. Tried uninstalling Autodesk files,as suggested by team
HKEY_CLASSES_ROOT\Installer\Products\<Product ID>
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\<Product ID>
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\<Product Name>
However I'm not clear how of following:
Autodesk Revit 2013 (English) 32/64 Bit http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/ESD/Autodesk_Revit_2013_English_Win_32-64bit....
Welcome to the community.
Please be aware that Revit 2013 is NOT supported on Windows 8. You will need to either install it to Windows 7 or upgrade to the Revit 2014 version.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19048377&linkID=9240617
Good Luck!
