Installation & Licensing
Active Member
ranjeet7
Message 1 of 13 (2,745 Views)
Problem in activation of product
2745 Views, 12 Replies
02-01-2011 07:43 PM
Please someone help me with this. Whenever I click on the activate button a white screen appears and I am unable to see the request code which is necessary to get the activation code for licencing of my product.
When I click on the activate button this screen appears: Click on the below pasted link to see the problem.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=6404339&linkID=9240697
I shall be greatly thankful
I am really sorry to hear the problem is still not resolved for you. In the mean time, the Technical Solution article has been updated at
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=6404339&linkID=9240617
Can you please go through all the listed steps in the document again?
Regards
Silvia
Silvia Menon
Support Specialist
Product Support
http://www.autodesk.com/autocad-support
Product Support
Silvia.Menon
Message 2 of 13 (2,707 Views)
Re: Problem in activation of product
02-02-2011 01:41 AM in reply to: ranjeet7
Hi Ranjeet,
the link you pasted in contains a screenshot of the problem, but also the steps to resolve it. Did you follow those instructions?
Best regards
Silvia
Silvia Menon
Support Specialist
Product Support
Active Member
ranjeet7
Message 3 of 13 (2,690 Views)
02-02-2011 03:40 AM in reply to: ranjeet7
of course i did....I tried the method which was explained by the pasted link but it didnt work for me. When i hit the mentioned command in the command prompt then it said: The module "jscript.dll" was loaded but the call to DllRegisterServer failed with error code 0x80004005. I further googled this error code to find they way to fix it but cud nt get over it.
JDMather
Message 4 of 13 (2,680 Views)
02-02-2011 04:50 AM in reply to: ranjeet7
Wrong forum, there is a separate forum for installation/activation problems
http://forums.autodesk.com/t5/Installation-Licensing/Blank-Activation-Screen/td-p/2862508
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015-SP1 64-bit
Product Support
Silvia.Menon
Message 5 of 13 (2,665 Views)
02-02-2011 05:29 AM in reply to: ranjeet7
can you please confirm what OS you are running and that you are attempting to register the dll logged on as local Administrator?
If you are running Vista or windows 7, try to run the command prompt with the "Run as Administrator" Option and attempt to register the dll again.
Any luck?
Regards
Silvia
Silvia Menon
Support Specialist
Product Support
Active Member
ranjeet7
Message 6 of 13 (2,617 Views)
02-02-2011 09:28 AM in reply to: ranjeet7
Hey I ran the command prompt as administrator and this time it was successful but even now when i click on activate button it shows the same stupid white window with those little radio buttons...
Product Support
Silvia.Menon
Message 7 of 13 (2,567 Views)
02-04-2011 03:12 AM in reply to: ranjeet7
Regards
Silvia
Silvia Menon
Support Specialist
Product Support
Active Member
ranjeet7
Message 8 of 13 (2,533 Views)
02-04-2011 05:11 PM in reply to: ranjeet7
Hey Silvia thankyou so very much for your last post. It really worked for me finally.
Member
stefan.guhl
Message 9 of 13 (458 Views)
11-25-2013 09:04 AM in reply to: Silvia.Menon
I have the same problem and have tried to do the steps from the link, but I couldn`t install the IE 8. My Windows 7 says that the system is to new for ie8.
Is there any sollution with the Mozilla Firefox?
Hope you can help me
Regards
Stefan
jessica.t
Message 10 of 13 (449 Views)
11-25-2013 10:52 AM in reply to: stefan.guhl
Hi Stefan,
Welcome to the Outtakes Community!
Could you please provide a screenings of the error you are receiving? From you description it does not sound familiar. Also, did you follow each step outlined before the previous post?
Thanks for you for any additional information you can provide.
Jessica Thrasher
