Installation & Licensing
Problem importing license onto a new laptop when old laptop not working
1 REPLY 1
georgeoney
305 Views, 1 Reply
I had AutoCAD LT 2012 installed on both a desktop and laptop machine. The screen laptop failed and is no longer useable. I have purchased a new laptop, exported the license from the desktop, then imported the license onto the new laptop. I then tried to import the license back onto the desktop and got an error message (too many installs). How do I import the license onto the desktop without being able to access the old laptop?
1 REPLY 1
philip.s
in reply to: georgeoney
Welcome to the community George!
It sounds like you're trying to import a license that is not available / has not first been exported.
If you wish to run the software on both machines and as you no longer have access to the previous license (broken laptop), you would simply need to proceed with the standard install and activation process. Should you run into any licensing issues at that point, please contact our License Assistance Team for direct support.
Here to help if additional clarification is needed, otherwise please accept as a solution so that others can benefit from this information.
Administrator Productivity
