I have a problem when I run the deployment of AutoCAD 2010 with SCCM. It is not possible to launch the deployment if I am not connected with an administrator account. The workstations are installed with Windows 7 Enterprise 32-bit. When I run the SCCM 2007 SP2 Deployment (prepared as directed by Autodesk) as a standard user, an error message appears and tells me that the copy functions can not be used. The process then seems to run in a loop and nothing happens. There is no specific information in the LOG file.
Is it due to the unfriendly security of Windows 7 (the UAC is disabled)? This problem is known? Should it be mandatory to be connected with an administrator account?
If someone has a suggestion it is welcome.
Vincent
