Installation & Licensing
Problem at the installation !
3 REPLIES 3
Warriorsam
416 Views, 3 Replies
At the middle of the installation of Autodesk Softimage 2013 I get that error !
"An error occured while installing this product.For more information view the installation log file"
But I can't understand what's the error in the log file..!
2013/9/30:22:47:22 Warriorsam WARRIORSAM-PC === Setup started on WARRIORSAM-PC by Warriorsam ===
2013/9/30:22:47:22 Warriorsam WARRIORSAM-PC Launch
2013/9/30:22:47:31 Warriorsam WARRIORSAM-PC === Setup ended ===
2013/9/30:22:47:25 Warriorsam WARRIORSAM-PC === Setup started on WARRIORSAM-PC by Warriorsam ===
2013/9/30:22:47:25 Warriorsam WARRIORSAM-PC Launch
2013/9/30:22:47:32 Warriorsam WARRIORSAM-PC PageOpen LaunchDialog
2013/9/30:22:47:40 Warriorsam WARRIORSAM-PC PageOpen LicenseDialog
2013/9/30:22:47:43 Warriorsam WARRIORSAM-PC PageOpen ProductInfoDialog
2013/9/30:22:48:58 Warriorsam WARRIORSAM-PC PageOpen ProductSelectionDialog2
2013/9/30:22:49:32 Warriorsam WARRIORSAM-PC PageOpen FullProgressDialog
2013/9/30:22:49:32 Warriorsam WARRIORSAM-PC Installing Autodesk Softimage 2013 64-bit: TRANSFORMS="C:\Users\WARRIO~1\AppData\Local\Temp\_AIAFC7.tmp\x64\Softimage\Softimage-2013-x64-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="F:\" INSTALLDIR="A:\Programmes installés\Softimage 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/9/30:22:56:52 Warriorsam WARRIORSAM-PC Install Autodesk Softimage 2013 64-bit Failed Installation aborted, Result=1603
If you can help me .. Thank you 🙂
3 REPLIES 3
Yannick.Karawa
in reply to: Warriorsam
Sorry to hear that you encounter issue with the installation of "Autodesk Softimage 2013".
Try to manually remove the VC++ and DotNet components from your computer from "uninstall or change a program" and reattempt the installation.
If it still fails, append the "setup.ini" file you use for the installation which is located in the same directory as the "Install.exe" and a Print screen of the error message.
For your information, make always sure to run the installation with Admin right and the antivirus deactivated.
Yannick Karawa
Warriorsam
in reply to: Yannick.Karawa
Hello
Same problem afther what you told me in the other message !
I put the setup.ini file in attachments!
Thank you!
TravisNave
What sticks out to me is that your installation folder is listed as A:\ drive.  That's odd...  Smiley Indifferent
Autodesk Forums:
Administrator Productivity
