Installation & Licensing
Paul-Mason
261 Views, 1 Reply
Preview Problem
This is when using WINDOWS  EXPLORE, when I go to the folder with my Inventor projects in it, I would always see a graphical representation of the IPT, IDW etc files. However now, after installing all I see id the standard icons as are shown on the new/open selection in the IV file.
SO I've tried repair, reinstall of IV, update from Windows Vista Ultimate to Windows 7 Ultimate still got the problem, so now I'm thinking that it is something to do with a registry setting but which one/s? Or there is a far simpler answer such as using the properties settings to correct this problem., such as which one of the DLL files has the necessary settings to correct this problem?
I've attached two screen shots to better show the problem, as can be seen all other file types show OK this just affects Inventor related files.
I prefer to see graphical representation of IV files in Windows Explorer as it is much easier to get the correct file so I'm desperate to get this problem solved.
Inventor 2023 Pro
HP Z420 workstation
Xeon 3.7Ghz CPU 8 Cores, 64 GB Ram
64bit (The Garbage known as) Windows 10 Pro
AMD FirePro V3900 (ATI FireGL) (1GB RAM)
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
1 REPLY 1
Paul-Mason
in reply to: Paul-Mason
Just an update for this.
Got this problem sorted it was caused by V-com Fix-it-utilities Pro, once this was un-installed and replaced with Norton all preview icons for IV returned to normal.
So as of date of posting, and almost 3 years after intially reporting this problem, V-com have NOT come up with any fix for this, a shame in a way as this set of utilities was very use-friendly and easy to use.
Inventor 2023 Pro
HP Z420 workstation
Administrator Productivity
