Installation & Licensing
Portable License Utility "cannot find any Autodesk Products"
2 REPLIES 2
XR600rk1611
522 Views, 2 Replies
We have two different machines in the office that for some reason have developed this problem of the Portable License Utility no longer working.  We don't use it a lot, but like anything, when we needed it today it bonks out.
When starting the "Portable License Utility" from the Start menu, it immediately comes up with an error stating "This program cannot find any AutoDesk products on this computer", and both machines most definitely DO have fully licensed/activated/operating copies of LDT companion 2009 on them.
Does anyone have any ideas what could be causing this behavior?  Thanks!
2 REPLIES 2
Hi vmx12,
I do not know why you are getting the error, but you might want to try using License Transfer Utility:
You will need an Internet Connection, and an Autodesk user ID and password, available from the Autodesk Register Once website:
https://registeronce.autodesk.com
More information about the "License Transfer Utility" can be found here:
http://docs.autodesk.com/ACD/2011/ENU/filesLIC/WS1a9193826455f5ff-3859b43c1209703a838e77.htm
For detailed instructions on how to export your license using License Transfer Utility can be found here:
http://docs.autodesk.com/ACD/2011/ENU/filesLIC/WS1a9193826455f5ff-3859b43c1209703a838-4865.htm
For detailed instructions on how to import your license using License Transfer Utility can be found here:
http://docs.autodesk.com/ACD/2011/ENU/filesLIC/WS1a9193826455f5ff-3859b43c1209703a838-484c.htm
For a video guide on how to use License Transfer Utility, please follow this link:
http://usa.autodesk.com/getdoc/id=TS13409518
Please let me know if this resolves your issue.
Timmy De Austria
Product Support | Up and Ready Blog | If my reply was helpful, please Kudo or Accept as Solution. 😉
I wanted to follow up whether my previous response resolves your issue. Please let me know if you need further asistance.
Timmy De Austria
Administrator Productivity
