Glad it helped!
Yes, adding anything else to the filename can't hurt; may as well take
advantage of the long names. All you need to track is the target PC; the
source PC is irrelevant.
It also helps to make the computer name as descriptive as possible in the
PLU's computer list. The important decision is in selecting the right
target computer, not necessarily in naming the output license transfer file!
Once you select it and hit "Export", that's the only place the license can
go.
A few more tips:
o You can always re-create the export file by going back to the source PC
and exporting again. You can only choose the same target PC as before, but
if the export file or code is lost or corrupted, you can recreate it.
o Sometimes the transfer code is more reliable than the file. Files can
get corrupted during transmission (you can zip them for extra safety). You
can use the code after the first time you transfer a license.
o On the source PC, if you export a license just before going home, but
suddenly find you have to do One More Urgent Thing, you can usually still
run the product for 24 hours using the "emergency license". This is
automatically activated by simply launching the product again, after export.
The 24-hour period begins the moment the product is launched. Note: this is
for emergencies, so you can't use it every day; it's allowed something like
once a month.
--Cy--
wrote in message news:5560913@discussion.autodesk.com...
Cy,
Your method worked perfectly! I like the idea of using ToLaptop and
ToDesktop, too. A visual nudge always helps knowing which way to go.
Initiall in my situation, there was only one user going back and forth. I
got into the mix updating the laptop for him, and did so by adding my
machine to go back and forth with. By using the default name for the
license, I think I screwed things up (and probably not paying attention when
going back to my machine and selecting the other machine in the process)
Would an additional failsafe for having more than one source machine on the
target be to add "_<3-letter initials>" to the endo of the license name? In
other words "ToLaptop_mel", or do you still have to be careful in selecting
the correct host machine when going back?
Thanks!
