Installation & Licensing
Port number used for network licensing of Autodesk products (Firewall Exception)
23 REPLIES 23
Message 1 of 24
david.lau
62148 Views, 23 Replies
If you are setting up a Firewall exception for Autodesk Network Licensing, you will need to know the following:
  • Port 2080 is used for the adskflex.exe
  • Port 27000-27009 is used for the lmgrd.exe
The default license file will start with the following 3 lines:
   SERVER Your-SERVER-name 0025b3282c6b
   USE_SERVER
   VENDOR adskflex port=2080
To force the lmgrd to use a particular port, just edit the network license file as noted below:
   SERVER Your-SERVER-name 0025b3282c6b 27000
   USE_SERVER
You do not need to change 2080 as this port has been reserved for Autodesk.
Firewall exception instructions are as noted below:
  • Incoming > Add Port > Name: Autodesk 2080 > Port Number:  2080 > Protocol TCP
  • Incoming > Add Port > Name: Autodesk 27000 > Port Number:  27000 > Protocol TCP
NOTE:  For Windows 7 and Windows Server 2008 R2, you can actually put in a range of ports. i.e. 27000-27009.  You may not need to force the system to look at a particular port number i.e. 27000.
The client license, if you have added the custom port on the server license file would be:
SERVER Your-SERVER-name 0 27000
USE_SERVER
David Lau
23 REPLIES 23
Message 21 of 24
Darin.Green
in reply to: mdhutchinson
Hi David,
The port range should be done within the Firewall, not inside of the license file.
I recommend opening port 2080, and one of the 2700#'s ports. Then, within the license file update the header to online use that port.
SERVER Your-SERVER-name 0025b3282c6b 27005
USE_SERVER
If this information was helpful, please consider using the Accept Solution
Message 22 of 24
Ezekiel12
in reply to: david.lau
does these pots apply also for Desktop subcription licensing? (Renting)
Thank you
Message 23 of 24
in reply to: TravisNave
HI,
Can i make Autocad listen to my client(normal c++ socket client program :that is pumping commands to autocad) on particular port.
If so how can i achieve it. Could you please elaborate.
Thank you so much.
Message 24 of 24
in reply to: Robert49494949
After adding firewall exceptions still was not able to get the client to check-out license. Enabling the firewall rule "File and Printer Sharing (Echo Request - ICMPv4-In)" fixed the issue.
Administrator Productivity
