Installation & Licensing
New Member
0 Kudos
Post 1 of 5
Pop-up window while opening a file
209 Views, 4 Replies
04-08-2014 10:28 AM
Hi, I am using LT 2014. I changed my laptop and managed to re-install the program. However, I found out that all files what I have saved after re-installation, gives annoying pop-up window while opening. Please see the capture attached.
Any ideas how to solve this out?
Thanks!
markus.makinen
Hello. Looks like the files were modified by some type of an external program. A 3rd party plugin maybe? Accepting the checkbox should stop this from appearing. You could test on another machine to see if this will appear on other machines.
Thank you for taking part in our community!
904 Kudos
Post 2 of 5
Re: Pop-up window while opening a file
04-08-2014 01:41 PM in reply to: markus.makinen
Check the box.  Then it will not verify the DWG origin anymore.
New Member
0 Kudos
Post 3 of 5
04-08-2014 09:15 PM in reply to: TravisNave
Well thank you TravisNave, but the thing is I do not want that pop-up occur when my customers open the file. I assume that your answer does not have solution for that? Thanks guys!
1,605 Kudos
Post 4 of 5
04-09-2014 05:51 AM in reply to: markus.makinen
You can't fix it for others except to try and re-save your files in LT2014 again (use RECOVER to fix them then SAVE).
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Product Support
70 Kudos
Post 5 of 5
04-09-2014 07:05 AM in reply to: markus.makinen
markus.makinen
David Dembkoski
