2014/12/1:20:31:41 Rebecca EPSMITH === Setup started on EPSMITH by Rebecca ===
2014/12/1:20:31:41 Rebecca EPSMITH Path_Length: 182
2014/12/1:20:31:41 Rebecca EPSMITH Current Directory C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_wi_en-US
2014/12/1:20:31:41 Rebecca EPSMITH Launch
2014/12/1:20:31:41 Rebecca EPSMITH CommandLine /url "http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/Autodesk_Inventor_2014_Eng_64bit_wi_en-US_Set... /SN 900-49854871 /PK 797F1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/12/1:20:31:41 Rebecca EPSMITH Current Directory C:\Users\Rebecca\AppData\Local\Temp\_AI48E3.tmp
2014/12/1:20:32:28 Rebecca EPSMITH === Setup ended ===
2014/12/1:20:31:44 Rebecca EPSMITH === Setup started on EPSMITH by Rebecca ===
2014/12/1:20:31:44 Rebecca EPSMITH Path_Length: 182
2014/12/1:20:31:44 Rebecca EPSMITH Current Directory C:\Users\Rebecca\AppData\Local\Temp\_AI48E3.tmp
2014/12/1:20:31:44 Rebecca EPSMITH Launch
2014/12/1:20:31:46 Rebecca EPSMITH Download Play SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/SETUP_...
2014/12/1:20:32:26 Rebecca EPSMITH Download Complete SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/SETUP_...
2014/12/1:20:32:26 Rebecca EPSMITH Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Rebecca\AppData\Local\Temp\_AI48E3.tmp\Setup\InventorUI.dll
2014/12/1:20:32:26 Rebecca EPSMITH Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/12/1:20:32:28 Rebecca EPSMITH PageOpen LaunchDialog
2014/12/1:20:33:17 Rebecca EPSMITH Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2014/12/1:20:33:17 Rebecca EPSMITH Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2014/12/1:20:33:19 Rebecca EPSMITH Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message:
2014/12/1:20:35:38 Rebecca EPSMITH PageOpen LicenseDialog
2014/12/1:20:35:38 Rebecca EPSMITH PageOpen ProductInfoDialog
2014/12/1:20:35:38 Rebecca EPSMITH PageOpen InventorFlavorSelectionDialog
2014/12/1:20:35:38 Rebecca EPSMITH Inventorui==DefaultLanguage: en-us
2014/12/1:20:35:38 Rebecca EPSMITH Inventorui==InstallName: INVENTOR
2014/12/1:20:35:38 Rebecca EPSMITH Inventorui==ProductName: Autodesk Inventor 2014
2014/12/1:20:35:38 Rebecca EPSMITH Inventorui==DisplayName: Autodesk® Inventor® 2014
2014/12/1:20:35:38 Rebecca EPSMITH Inventorui==DeploymentName:
2014/12/1:20:35:38 Rebecca EPSMITH Inventorui==SetupTitle: Autodesk Inventor 2014
2014/12/1:20:35:38 Rebecca EPSMITH Inventorui==ConfigTransform:
2014/12/1:20:35:38 Rebecca EPSMITH Inventorui==ExeParams:
2014/12/1:20:35:38 Rebecca EPSMITH Inventorui==ProductCode: {7F4DD591-1864-0001-0000-7107D70F3DB4}
2014/12/1:20:35:38 Rebecca EPSMITH Inventorui==SupportLink:
2014/12/1:20:35:38 Rebecca EPSMITH Inventorui==InfotainmentLink:
2014/12/1:20:35:38 Rebecca EPSMITH Inventorui==MsiFileName: inventor.msi
2014/12/1:20:35:38 Rebecca EPSMITH Inventorui==AdminImageConfigName: Imgx64
2014/12/1:20:35:38 Rebecca EPSMITH Inventorui==AdminImageRoot:
2014/12/1:20:35:38 Rebecca EPSMITH Inventorui==GetBaseDeploymentName:
2014/12/1:20:35:38 Rebecca EPSMITH Inventorui==DeploymentLocation:
2014/12/1:20:35:38 Rebecca EPSMITH Inventorui==DocumentLink: http://autodesk.com/wikihelp-inventor-install-2014-enu
2014/12/1:20:35:38 Rebecca EPSMITH Inventorui==InstallDeploymentShortcut:
2014/12/1:20:35:38 Rebecca EPSMITH Inventorui==ModifyDeploymentShortcut:
2014/12/1:20:35:38 Rebecca EPSMITH Inventorui==SetupLockType: 2
2014/12/1:20:35:38 Rebecca EPSMITH Inventorui==SetupNetworkType: 1
2014/12/1:20:35:38 Rebecca EPSMITH Inventorui==SystemLocale: 1033
2014/12/1:20:35:38 Rebecca EPSMITH Inventorui==EvalMsiFilePath: C:\Users\Rebecca\AppData\Local\Temp\_AI48E3.tmp\SetupRes\eval.msi
2014/12/1:20:35:38 Rebecca EPSMITH Inventorui==EulaPath: C:\Autodesk\WI\Autodesk Inventor 2014\EULA
2014/12/1:20:35:38 Rebecca EPSMITH Inventorui==InstallLogPath: C:\Users\Rebecca\AppData\Local\Temp\Inventor2014Install.log
2014/12/1:20:35:38 Rebecca EPSMITH Inventorui==ConfigFile: C:\Users\Rebecca\AppData\Local\Temp\_AI48E3.tmp\Setup.ini
2014/12/1:20:35:38 Rebecca EPSMITH Inventorui==SetupPath: C:\Users\Rebecca\AppData\Local\Temp\_AI48E3.tmp\
2014/12/1:20:35:38 Rebecca EPSMITH Inventorui==NetworkLogPath:
2014/12/1:20:35:38 Rebecca EPSMITH Inventorui==SourceRoot: C:\Autodesk\WI\Autodesk Inventor 2014
2014/12/1:20:39:56 Rebecca EPSMITH Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2014/12/1:20:39:56 Rebecca EPSMITH PageOpen ProductSelectionDialog2
2014/12/1:20:40:09 Rebecca EPSMITH PageOpen FullProgressDialog
2014/12/1:20:40:10 Rebecca EPSMITH Download Play DIRECTX http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/DIRECT...
2014/12/1:20:40:13 Rebecca EPSMITH Download Aborted DIRECTX http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/DIRECT...
2014/12/1:20:40:13 Rebecca EPSMITH Install DirectX® Runtime Failed Download Failed, Installation aborted, Result=1603
2014/12/1:20:40:14 Rebecca EPSMITH Download Play CMILL http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/CMILL....
2014/12/1:20:58:29 Rebecca EPSMITH Download Aborted CMILL http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/CMILL....
2014/12/1:20:58:29 Rebecca EPSMITH Download User Cancel CMILL http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/CMILL....
2014/12/1:20:58:30 Rebecca EPSMITH PageOpen InstallCompleteDialog
2014/12/1:20:58:38 Rebecca EPSMITH === Setup ended ===
2014/12/1:21:04:14 Rebecca EPSMITH === Setup started on EPSMITH by Rebecca ===
2014/12/1:21:04:14 Rebecca EPSMITH Path_Length: 182
2014/12/1:21:04:14 Rebecca EPSMITH Current Directory C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_wi_en-US
2014/12/1:21:04:14 Rebecca EPSMITH Launch
2014/12/1:21:04:14 Rebecca EPSMITH CommandLine /url "http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/Autodesk_Inventor_2014_Eng_64bit_wi_en-US_Set... /SN 900-49854871 /PK 797F1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/12/1:21:04:14 Rebecca EPSMITH Current Directory C:\Users\Rebecca\AppData\Local\Temp\_AI58BF.tmp
2014/12/1:21:04:18 Rebecca EPSMITH === Setup ended ===
2014/12/1:21:04:16 Rebecca EPSMITH === Setup started on EPSMITH by Rebecca ===
2014/12/1:21:04:16 Rebecca EPSMITH Path_Length: 182
2014/12/1:21:04:16 Rebecca EPSMITH Current Directory C:\Users\Rebecca\AppData\Local\Temp\_AI58BF.tmp
2014/12/1:21:04:16 Rebecca EPSMITH Launch
2014/12/1:21:04:17 Rebecca EPSMITH Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/SETUP_...
2014/12/1:21:04:17 Rebecca EPSMITH Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Rebecca\AppData\Local\Temp\_AI58BF.tmp\Setup\InventorUI.dll
2014/12/1:21:04:17 Rebecca EPSMITH Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/12/1:21:04:18 Rebecca EPSMITH PageOpen LaunchDialog
2014/12/1:21:04:23 Rebecca EPSMITH Inventorui== Parameter: Prereq_8 SetupMode:7 InstallState:1 InstallAction:0 Message:
2014/12/1:21:04:23 Rebecca EPSMITH PageOpen LicenseDialog
2014/12/1:21:04:23 Rebecca EPSMITH PageOpen ProductSelectionDialog2
2014/12/1:21:04:34 Rebecca EPSMITH PageOpen FullProgressDialog
2014/12/1:21:04:34 Rebecca EPSMITH Installing Network License Manager: INSTALLDIR="C:\Program Files\Autodesk\Autodesk Network License Manager\" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2014" SETUP_PACKAGECODE={8CB42675-1800-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Inventor 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/12/1:21:04:37 Rebecca EPSMITH Install Network License Manager Succeeded
2014/12/1:21:04:38 Rebecca EPSMITH Download Play CADM http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/CADM_x...
2014/12/1:21:04:41 Rebecca EPSMITH Download Complete CADM http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/CADM_x...
2014/12/1:21:04:41 Rebecca EPSMITH Installing Autodesk CAD Manager Tools: INSTALLDIR="C:\Program Files\Autodesk\Autodesk CAD Manager Tools\" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2014" SETUP_PACKAGECODE={8CB42675-1800-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Inventor 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/12/1:21:04:45 Rebecca EPSMITH Install Autodesk CAD Manager Tools Succeeded
2014/12/1:21:04:45 Rebecca EPSMITH PageOpen InstallCompleteDialog
2014/12/1:21:04:52 Rebecca EPSMITH === Setup ended ===
2014/12/1:21:05:15 Rebecca EPSMITH === Setup started on EPSMITH by Rebecca ===
2014/12/1:21:05:15 Rebecca EPSMITH Path_Length: 182
2014/12/1:21:05:15 Rebecca EPSMITH Current Directory C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_wi_en-US
2014/12/1:21:05:15 Rebecca EPSMITH Launch
2014/12/1:21:05:15 Rebecca EPSMITH CommandLine /url "http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/Autodesk_Inventor_2014_Eng_64bit_wi_en-US_Set... /SN 900-49854871 /PK 797F1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/12/1:21:05:15 Rebecca EPSMITH Current Directory C:\Users\Rebecca\AppData\Local\Temp\_AI45CF.tmp
2014/12/1:21:05:19 Rebecca EPSMITH === Setup ended ===
2014/12/1:21:05:17 Rebecca EPSMITH === Setup started on EPSMITH by Rebecca ===
2014/12/1:21:05:17 Rebecca EPSMITH Path_Length: 182
2014/12/1:21:05:17 Rebecca EPSMITH Current Directory C:\Users\Rebecca\AppData\Local\Temp\_AI45CF.tmp
2014/12/1:21:05:17 Rebecca EPSMITH Launch
2014/12/1:21:05:18 Rebecca EPSMITH Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/SETUP_...
2014/12/1:21:05:18 Rebecca EPSMITH Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Rebecca\AppData\Local\Temp\_AI45CF.tmp\Setup\InventorUI.dll
2014/12/1:21:05:18 Rebecca EPSMITH Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/12/1:21:05:19 Rebecca EPSMITH PageOpen LaunchDialog
2014/12/1:21:05:29 Rebecca EPSMITH Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2014/12/1:21:05:29 Rebecca EPSMITH Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2014/12/1:21:05:29 Rebecca EPSMITH Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message:
2014/12/1:21:05:53 Rebecca EPSMITH PageOpen LicenseDialog
2014/12/1:21:05:53 Rebecca EPSMITH PageOpen ProductInfoDialog
2014/12/1:21:05:53 Rebecca EPSMITH PageOpen InventorFlavorSelectionDialog
2014/12/1:21:05:53 Rebecca EPSMITH Inventorui==DefaultLanguage: en-us
2014/12/1:21:05:53 Rebecca EPSMITH Inventorui==InstallName: INVENTOR
2014/12/1:21:05:53 Rebecca EPSMITH Inventorui==ProductName: Autodesk Inventor 2014
2014/12/1:21:05:53 Rebecca EPSMITH Inventorui==DisplayName: Autodesk® Inventor® 2014
2014/12/1:21:05:53 Rebecca EPSMITH Inventorui==DeploymentName:
2014/12/1:21:05:53 Rebecca EPSMITH Inventorui==SetupTitle: Autodesk Inventor 2014
2014/12/1:21:05:53 Rebecca EPSMITH Inventorui==ConfigTransform:
2014/12/1:21:05:53 Rebecca EPSMITH Inventorui==ExeParams:
2014/12/1:21:05:53 Rebecca EPSMITH Inventorui==ProductCode: {7F4DD591-1864-0001-0000-7107D70F3DB4}
2014/12/1:21:05:53 Rebecca EPSMITH Inventorui==SupportLink:
2014/12/1:21:05:53 Rebecca EPSMITH Inventorui==InfotainmentLink:
2014/12/1:21:05:53 Rebecca EPSMITH Inventorui==MsiFileName: inventor.msi
2014/12/1:21:05:53 Rebecca EPSMITH Inventorui==AdminImageConfigName: Imgx64
2014/12/1:21:05:53 Rebecca EPSMITH Inventorui==AdminImageRoot:
2014/12/1:21:05:53 Rebecca EPSMITH Inventorui==GetBaseDeploymentName:
2014/12/1:21:05:53 Rebecca EPSMITH Inventorui==DeploymentLocation:
2014/12/1:21:05:53 Rebecca EPSMITH Inventorui==DocumentLink: http://autodesk.com/wikihelp-inventor-install-2014-enu
2014/12/1:21:05:53 Rebecca EPSMITH Inventorui==InstallDeploymentShortcut:
2014/12/1:21:05:53 Rebecca EPSMITH Inventorui==ModifyDeploymentShortcut:
2014/12/1:21:05:53 Rebecca EPSMITH Inventorui==SetupLockType: 2
2014/12/1:21:05:53 Rebecca EPSMITH Inventorui==SetupNetworkType: 1
2014/12/1:21:05:53 Rebecca EPSMITH Inventorui==SystemLocale: 1033
2014/12/1:21:05:53 Rebecca EPSMITH Inventorui==EvalMsiFilePath: C:\Users\Rebecca\AppData\Local\Temp\_AI45CF.tmp\SetupRes\eval.msi
2014/12/1:21:05:53 Rebecca EPSMITH Inventorui==EulaPath: C:\Autodesk\WI\Autodesk Inventor 2014\EULA
2014/12/1:21:05:53 Rebecca EPSMITH Inventorui==InstallLogPath: C:\Users\Rebecca\AppData\Local\Temp\Inventor2014Install.log
2014/12/1:21:05:53 Rebecca EPSMITH Inventorui==ConfigFile: C:\Users\Rebecca\AppData\Local\Temp\_AI45CF.tmp\Setup.ini
2014/12/1:21:05:53 Rebecca EPSMITH Inventorui==SetupPath: C:\Users\Rebecca\AppData\Local\Temp\_AI45CF.tmp\
2014/12/1:21:05:53 Rebecca EPSMITH Inventorui==NetworkLogPath:
2014/12/1:21:05:53 Rebecca EPSMITH Inventorui==SourceRoot: C:\Autodesk\WI\Autodesk Inventor 2014
2014/12/1:21:05:57 Rebecca EPSMITH Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2014/12/1:21:05:57 Rebecca EPSMITH PageOpen ProductSelectionDialog2
2014/12/1:21:06:16 Rebecca EPSMITH PageOpen FullProgressDialog
2014/12/1:21:06:17 Rebecca EPSMITH Download Play DIRECTX http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/DIRECT...
2014/12/1:21:06:20 Rebecca EPSMITH Download Complete DIRECTX http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/DIRECT...
2014/12/1:21:06:20 Rebecca EPSMITH Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Inventor 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/12/1:21:07:10 Rebecca EPSMITH Install DirectX® Runtime Succeeded
2014/12/1:21:07:10 Rebecca EPSMITH Download Play CMILL http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/CMILL....
2014/12/1:21:08:13 Rebecca EPSMITH Download Aborted CMILL http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/CMILL....
2014/12/1:21:08:13 Rebecca EPSMITH Install Autodesk Material Library 2014 - Low Image Library Failed Download Failed, Installation aborted, Result=1603
2014/12/1:21:08:13 Rebecca EPSMITH Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/12/1:21:08:15 Rebecca EPSMITH PageOpen InstallCompleteDialog
2014/12/1:21:08:31 Rebecca EPSMITH === Setup ended ===
2014/12/1:21:11:06 Rebecca EPSMITH === Setup started on EPSMITH by Rebecca ===
2014/12/1:21:11:06 Rebecca EPSMITH Path_Length: 182
2014/12/1:21:11:06 Rebecca EPSMITH Current Directory C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_wi_en-US
2014/12/1:21:11:06 Rebecca EPSMITH Launch
2014/12/1:21:11:06 Rebecca EPSMITH CommandLine /url "http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/Autodesk_Inventor_2014_Eng_64bit_wi_en-US_Set... /SN 900-49854871 /PK 797F1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/12/1:21:11:06 Rebecca EPSMITH Current Directory C:\Users\Rebecca\AppData\Local\Temp\_AIA0F7.tmp
2014/12/1:21:11:12 Rebecca EPSMITH === Setup ended ===
2014/12/1:21:11:10 Rebecca EPSMITH === Setup started on EPSMITH by Rebecca ===
2014/12/1:21:11:10 Rebecca EPSMITH Path_Length: 182
2014/12/1:21:11:10 Rebecca EPSMITH Current Directory C:\Users\Rebecca\AppData\Local\Temp\_AIA0F7.tmp
2014/12/1:21:11:10 Rebecca EPSMITH Launch
2014/12/1:21:11:10 Rebecca EPSMITH Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/SETUP_...
2014/12/1:21:11:11 Rebecca EPSMITH Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Rebecca\AppData\Local\Temp\_AIA0F7.tmp\Setup\InventorUI.dll
2014/12/1:21:11:11 Rebecca EPSMITH Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/12/1:21:11:12 Rebecca EPSMITH PageOpen LaunchDialog
2014/12/1:21:11:23 Rebecca EPSMITH Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2014/12/1:21:11:23 Rebecca EPSMITH Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2014/12/1:21:11:23 Rebecca EPSMITH Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message:
2014/12/1:21:11:47 Rebecca EPSMITH PageOpen LicenseDialog
2014/12/1:21:11:47 Rebecca EPSMITH PageOpen ProductInfoDialog
2014/12/1:21:11:47 Rebecca EPSMITH PageOpen InventorFlavorSelectionDialog
2014/12/1:21:11:47 Rebecca EPSMITH Inventorui==DefaultLanguage: en-us
2014/12/1:21:11:47 Rebecca EPSMITH Inventorui==InstallName: INVENTOR
2014/12/1:21:11:47 Rebecca EPSMITH Inventorui==ProductName: Autodesk Inventor 2014
2014/12/1:21:11:47 Rebecca EPSMITH Inventorui==DisplayName: Autodesk® Inventor® 2014
2014/12/1:21:11:47 Rebecca EPSMITH Inventorui==DeploymentName:
2014/12/1:21:11:47 Rebecca EPSMITH Inventorui==SetupTitle: Autodesk Inventor 2014
2014/12/1:21:11:47 Rebecca EPSMITH Inventorui==ConfigTransform:
2014/12/1:21:11:47 Rebecca EPSMITH Inventorui==ExeParams:
2014/12/1:21:11:47 Rebecca EPSMITH Inventorui==ProductCode: {7F4DD591-1864-0001-0000-7107D70F3DB4}
2014/12/1:21:11:47 Rebecca EPSMITH Inventorui==SupportLink:
2014/12/1:21:11:47 Rebecca EPSMITH Inventorui==InfotainmentLink:
2014/12/1:21:11:47 Rebecca EPSMITH Inventorui==MsiFileName: inventor.msi
2014/12/1:21:11:47 Rebecca EPSMITH Inventorui==AdminImageConfigName: Imgx64
2014/12/1:21:11:47 Rebecca EPSMITH Inventorui==AdminImageRoot:
2014/12/1:21:11:47 Rebecca EPSMITH Inventorui==GetBaseDeploymentName:
2014/12/1:21:11:47 Rebecca EPSMITH Inventorui==DeploymentLocation:
2014/12/1:21:11:47 Rebecca EPSMITH Inventorui==DocumentLink: http://autodesk.com/wikihelp-inventor-install-2014-enu
2014/12/1:21:11:47 Rebecca EPSMITH Inventorui==InstallDeploymentShortcut:
2014/12/1:21:11:47 Rebecca EPSMITH Inventorui==ModifyDeploymentShortcut:
2014/12/1:21:11:47 Rebecca EPSMITH Inventorui==SetupLockType: 2
2014/12/1:21:11:47 Rebecca EPSMITH Inventorui==SetupNetworkType: 1
2014/12/1:21:11:47 Rebecca EPSMITH Inventorui==SystemLocale: 1033
2014/12/1:21:11:47 Rebecca EPSMITH Inventorui==EvalMsiFilePath: C:\Users\Rebecca\AppData\Local\Temp\_AIA0F7.tmp\SetupRes\eval.msi
2014/12/1:21:11:47 Rebecca EPSMITH Inventorui==EulaPath: C:\Autodesk\WI\Autodesk Inventor 2014\EULA
2014/12/1:21:11:47 Rebecca EPSMITH Inventorui==InstallLogPath: C:\Users\Rebecca\AppData\Local\Temp\Inventor2014Install.log
2014/12/1:21:11:47 Rebecca EPSMITH Inventorui==ConfigFile: C:\Users\Rebecca\AppData\Local\Temp\_AIA0F7.tmp\Setup.ini
2014/12/1:21:11:47 Rebecca EPSMITH Inventorui==SetupPath: C:\Users\Rebecca\AppData\Local\Temp\_AIA0F7.tmp\
2014/12/1:21:11:47 Rebecca EPSMITH Inventorui==NetworkLogPath:
2014/12/1:21:11:47 Rebecca EPSMITH Inventorui==SourceRoot: C:\Autodesk\WI\Autodesk Inventor 2014
2014/12/1:21:12:25 Rebecca EPSMITH Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2014/12/1:21:12:25 Rebecca EPSMITH PageOpen ProductSelectionDialog2
2014/12/1:21:12:36 Rebecca EPSMITH PageOpen FullProgressDialog
2014/12/1:21:12:37 Rebecca EPSMITH Download Skipped DIRECTX http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/DIRECT...
2014/12/1:21:12:37 Rebecca EPSMITH Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Inventor 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/12/1:21:12:43 Rebecca EPSMITH Install DirectX® Runtime Succeeded
2014/12/1:21:12:44 Rebecca EPSMITH Download Play CMILL http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/CMILL....
2014/12/1:21:13:46 Rebecca EPSMITH Download Aborted CMILL http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/CMILL....
2014/12/1:21:13:46 Rebecca EPSMITH Install Autodesk Material Library 2014 - Low Image Library Failed Download Failed, Installation aborted, Result=1603
2014/12/1:21:13:46 Rebecca EPSMITH Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/12/1:21:13:47 Rebecca EPSMITH PageOpen InstallCompleteDialog
2014/12/1:21:13:59 Rebecca EPSMITH === Setup ended ===
2014/12/1:21:14:23 Rebecca EPSMITH === Setup started on EPSMITH by Rebecca ===
2014/12/1:21:14:23 Rebecca EPSMITH Path_Length: 182
2014/12/1:21:14:23 Rebecca EPSMITH Current Directory C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_wi_en-US
2014/12/1:21:14:23 Rebecca EPSMITH Launch
2014/12/1:21:14:23 Rebecca EPSMITH CommandLine /url "http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/Autodesk_Inventor_2014_Eng_64bit_wi_en-US_Set... /SN 900-49854871 /PK 797F1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/12/1:21:14:23 Rebecca EPSMITH Current Directory C:\Users\Rebecca\AppData\Local\Temp\_AIA473.tmp
2014/12/1:21:14:28 Rebecca EPSMITH === Setup ended ===
2014/12/1:21:14:26 Rebecca EPSMITH === Setup started on EPSMITH by Rebecca ===
2014/12/1:21:14:26 Rebecca EPSMITH Path_Length: 182
2014/12/1:21:14:26 Rebecca EPSMITH Current Directory C:\Users\Rebecca\AppData\Local\Temp\_AIA473.tmp
2014/12/1:21:14:26 Rebecca EPSMITH Launch
2014/12/1:21:14:27 Rebecca EPSMITH Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/SETUP_...
2014/12/1:21:14:27 Rebecca EPSMITH Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Rebecca\AppData\Local\Temp\_AIA473.tmp\Setup\InventorUI.dll
2014/12/1:21:14:27 Rebecca EPSMITH Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/12/1:21:14:28 Rebecca EPSMITH PageOpen LaunchDialog
2014/12/1:21:15:08 Rebecca EPSMITH Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2014/12/1:21:15:08 Rebecca EPSMITH Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2014/12/1:21:15:08 Rebecca EPSMITH Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message:
2014/12/1:21:15:32 Rebecca EPSMITH PageOpen LicenseDialog
2014/12/1:21:15:32 Rebecca EPSMITH PageOpen ProductInfoDialog
2014/12/1:21:15:32 Rebecca EPSMITH PageOpen InventorFlavorSelectionDialog
2014/12/1:21:15:32 Rebecca EPSMITH Inventorui==DefaultLanguage: en-us
2014/12/1:21:15:32 Rebecca EPSMITH Inventorui==InstallName: INVENTOR
2014/12/1:21:15:32 Rebecca EPSMITH Inventorui==ProductName: Autodesk Inventor 2014
2014/12/1:21:15:32 Rebecca EPSMITH Inventorui==DisplayName: Autodesk® Inventor® 2014
2014/12/1:21:15:32 Rebecca EPSMITH Inventorui==DeploymentName:
2014/12/1:21:15:32 Rebecca EPSMITH Inventorui==SetupTitle: Autodesk Inventor 2014
2014/12/1:21:15:32 Rebecca EPSMITH Inventorui==ConfigTransform:
2014/12/1:21:15:32 Rebecca EPSMITH Inventorui==ExeParams:
2014/12/1:21:15:32 Rebecca EPSMITH Inventorui==ProductCode: {7F4DD591-1864-0001-0000-7107D70F3DB4}
2014/12/1:21:15:32 Rebecca EPSMITH Inventorui==SupportLink:
2014/12/1:21:15:32 Rebecca EPSMITH Inventorui==InfotainmentLink:
2014/12/1:21:15:32 Rebecca EPSMITH Inventorui==MsiFileName: inventor.msi
2014/12/1:21:15:32 Rebecca EPSMITH Inventorui==AdminImageConfigName: Imgx64
2014/12/1:21:15:32 Rebecca EPSMITH Inventorui==AdminImageRoot:
2014/12/1:21:15:32 Rebecca EPSMITH Inventorui==GetBaseDeploymentName:
2014/12/1:21:15:32 Rebecca EPSMITH Inventorui==DeploymentLocation:
2014/12/1:21:15:32 Rebecca EPSMITH Inventorui==DocumentLink: http://autodesk.com/wikihelp-inventor-install-2014-enu
2014/12/1:21:15:32 Rebecca EPSMITH Inventorui==InstallDeploymentShortcut:
2014/12/1:21:15:32 Rebecca EPSMITH Inventorui==ModifyDeploymentShortcut:
2014/12/1:21:15:32 Rebecca EPSMITH Inventorui==SetupLockType: 2
2014/12/1:21:15:32 Rebecca EPSMITH Inventorui==SetupNetworkType: 1
2014/12/1:21:15:32 Rebecca EPSMITH Inventorui==SystemLocale: 1033
2014/12/1:21:15:32 Rebecca EPSMITH Inventorui==EvalMsiFilePath: C:\Users\Rebecca\AppData\Local\Temp\_AIA473.tmp\SetupRes\eval.msi
2014/12/1:21:15:32 Rebecca EPSMITH Inventorui==EulaPath: C:\Autodesk\WI\Autodesk Inventor 2014\EULA
2014/12/1:21:15:32 Rebecca EPSMITH Inventorui==InstallLogPath: C:\Users\Rebecca\AppData\Local\Temp\Inventor2014Install.log
2014/12/1:21:15:32 Rebecca EPSMITH Inventorui==ConfigFile: C:\Users\Rebecca\AppData\Local\Temp\_AIA473.tmp\Setup.ini
2014/12/1:21:15:32 Rebecca EPSMITH Inventorui==SetupPath: C:\Users\Rebecca\AppData\Local\Temp\_AIA473.tmp\
2014/12/1:21:15:32 Rebecca EPSMITH Inventorui==NetworkLogPath:
2014/12/1:21:15:32 Rebecca EPSMITH Inventorui==SourceRoot: C:\Autodesk\WI\Autodesk Inventor 2014
2014/12/1:21:15:36 Rebecca EPSMITH Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2014/12/1:21:15:36 Rebecca EPSMITH PageOpen ProductSelectionDialog2
2014/12/1:21:15:46 Rebecca EPSMITH PageOpen FullProgressDialog
2014/12/1:21:15:47 Rebecca EPSMITH Download Skipped DIRECTX http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/DIRECT...
2014/12/1:21:15:47 Rebecca EPSMITH Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Inventor 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/12/1:21:15:54 Rebecca EPSMITH Install DirectX® Runtime Succeeded
2014/12/1:21:15:56 Rebecca EPSMITH Download Play CMILL http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/CMILL....
2014/12/1:21:17:05 Rebecca EPSMITH Download Aborted CMILL http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/CMILL....
2014/12/1:21:17:05 Rebecca EPSMITH Install Autodesk Material Library 2014 - Low Image Library Failed Download Failed, Installation aborted, Result=1603
2014/12/1:21:17:06 Rebecca EPSMITH Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/12/1:21:17:07 Rebecca EPSMITH PageOpen InstallCompleteDialog
2014/12/1:21:26:51 Rebecca EPSMITH === Setup ended ===
2014/12/1:21:40:35 Rebecca EPSMITH === Setup started on EPSMITH by Rebecca ===
2014/12/1:21:40:35 Rebecca EPSMITH Path_Length: 182
2014/12/1:21:40:35 Rebecca EPSMITH Current Directory C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_wi_en-US
2014/12/1:21:40:35 Rebecca EPSMITH Launch
2014/12/1:21:40:35 Rebecca EPSMITH CommandLine /url "http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/Autodesk_Inventor_2014_Eng_64bit_wi_en-US_Set... /SN 900-49854871 /PK 797F1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/12/1:21:40:35 Rebecca EPSMITH Current Directory C:\Users\Rebecca\AppData\Local\Temp\_AIA086.tmp
2014/12/1:21:40:41 Rebecca EPSMITH === Setup ended ===
2014/12/1:21:40:38 Rebecca EPSMITH === Setup started on EPSMITH by Rebecca ===
2014/12/1:21:40:38 Rebecca EPSMITH Path_Length: 182
2014/12/1:21:40:38 Rebecca EPSMITH Current Directory C:\Users\Rebecca\AppData\Local\Temp\_AIA086.tmp
2014/12/1:21:40:38 Rebecca EPSMITH Launch
2014/12/1:21:40:39 Rebecca EPSMITH Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/SETUP_...
2014/12/1:21:40:39 Rebecca EPSMITH Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Rebecca\AppData\Local\Temp\_AIA086.tmp\Setup\InventorUI.dll
2014/12/1:21:40:39 Rebecca EPSMITH Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/12/1:21:40:41 Rebecca EPSMITH PageOpen LaunchDialog
2014/12/1:21:41:04 Rebecca EPSMITH Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2014/12/1:21:41:04 Rebecca EPSMITH Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2014/12/1:21:41:05 Rebecca EPSMITH Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message:
2014/12/1:21:41:29 Rebecca EPSMITH PageOpen LicenseDialog
2014/12/1:21:41:29 Rebecca EPSMITH PageOpen ProductInfoDialog
2014/12/1:21:41:29 Rebecca EPSMITH PageOpen InventorFlavorSelectionDialog
2014/12/1:21:41:29 Rebecca EPSMITH Inventorui==DefaultLanguage: en-us
2014/12/1:21:41:29 Rebecca EPSMITH Inventorui==InstallName: INVENTOR
2014/12/1:21:41:29 Rebecca EPSMITH Inventorui==ProductName: Autodesk Inventor 2014
2014/12/1:21:41:29 Rebecca EPSMITH Inventorui==DisplayName: Autodesk® Inventor® 2014
2014/12/1:21:41:29 Rebecca EPSMITH Inventorui==DeploymentName:
2014/12/1:21:41:29 Rebecca EPSMITH Inventorui==SetupTitle: Autodesk Inventor 2014
2014/12/1:21:41:29 Rebecca EPSMITH Inventorui==ConfigTransform:
2014/12/1:21:41:29 Rebecca EPSMITH Inventorui==ExeParams:
2014/12/1:21:41:29 Rebecca EPSMITH Inventorui==ProductCode: {7F4DD591-1864-0001-0000-7107D70F3DB4}
2014/12/1:21:41:29 Rebecca EPSMITH Inventorui==SupportLink:
2014/12/1:21:41:29 Rebecca EPSMITH Inventorui==InfotainmentLink:
2014/12/1:21:41:29 Rebecca EPSMITH Inventorui==MsiFileName: inventor.msi
2014/12/1:21:41:29 Rebecca EPSMITH Inventorui==AdminImageConfigName: Imgx64
2014/12/1:21:41:29 Rebecca EPSMITH Inventorui==AdminImageRoot:
2014/12/1:21:41:29 Rebecca EPSMITH Inventorui==GetBaseDeploymentName:
2014/12/1:21:41:29 Rebecca EPSMITH Inventorui==DeploymentLocation:
2014/12/1:21:41:29 Rebecca EPSMITH Inventorui==DocumentLink: http://autodesk.com/wikihelp-inventor-install-2014-enu
2014/12/1:21:41:29 Rebecca EPSMITH Inventorui==InstallDeploymentShortcut:
2014/12/1:21:41:29 Rebecca EPSMITH Inventorui==ModifyDeploymentShortcut:
2014/12/1:21:41:29 Rebecca EPSMITH Inventorui==SetupLockType: 2
2014/12/1:21:41:29 Rebecca EPSMITH Inventorui==SetupNetworkType: 1
2014/12/1:21:41:29 Rebecca EPSMITH Inventorui==SystemLocale: 1033
2014/12/1:21:41:29 Rebecca EPSMITH Inventorui==EvalMsiFilePath: C:\Users\Rebecca\AppData\Local\Temp\_AIA086.tmp\SetupRes\eval.msi
2014/12/1:21:41:29 Rebecca EPSMITH Inventorui==EulaPath: C:\Autodesk\WI\Autodesk Inventor 2014\EULA
2014/12/1:21:41:29 Rebecca EPSMITH Inventorui==InstallLogPath: C:\Users\Rebecca\AppData\Local\Temp\Inventor2014Install.log
2014/12/1:21:41:29 Rebecca EPSMITH Inventorui==ConfigFile: C:\Users\Rebecca\AppData\Local\Temp\_AIA086.tmp\Setup.ini
2014/12/1:21:41:29 Rebecca EPSMITH Inventorui==SetupPath: C:\Users\Rebecca\AppData\Local\Temp\_AIA086.tmp\
2014/12/1:21:41:29 Rebecca EPSMITH Inventorui==NetworkLogPath:
2014/12/1:21:41:29 Rebecca EPSMITH Inventorui==SourceRoot: C:\Autodesk\WI\Autodesk Inventor 2014
2014/12/1:21:42:38 Rebecca EPSMITH Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2014/12/1:21:42:38 Rebecca EPSMITH PageOpen ProductSelectionDialog2
2014/12/1:21:42:47 Rebecca EPSMITH PageOpen FullProgressDialog
2014/12/1:21:42:48 Rebecca EPSMITH Download Play VCREDIST2005SP1ATLX64 http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/VCREDI...
2014/12/1:21:42:50 Rebecca EPSMITH Download Complete VCREDIST2005SP1ATLX64 http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/VCREDI...
2014/12/1:21:42:50 Rebecca EPSMITH Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\WI\Autodesk Inventor 2014\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Rebecca\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/12/1:21:42:58 Rebecca EPSMITH Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Succeeded
2014/12/1:21:42:58 Rebecca EPSMITH Download Play VCREDIST2005SP1ATLX86 http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/VCREDI...
2014/12/1:21:43:00 Rebecca EPSMITH Download Complete VCREDIST2005SP1ATLX86 http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/VCREDI...
2014/12/1:21:43:00 Rebecca EPSMITH Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\Autodesk\WI\Autodesk Inventor 2014\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Rebecca\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/12/1:21:43:07 Rebecca EPSMITH Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Succeeded
2014/12/1:21:43:09 Rebecca EPSMITH Download Play VCREDIST2008SP1X64_6161 http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/VCREDI...
2014/12/1:21:43:11 Rebecca EPSMITH Download Complete VCREDIST2008SP1X64_6161 http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/VCREDI...
2014/12/1:21:43:12 Rebecca EPSMITH Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161: "C:\Autodesk\WI\Autodesk Inventor 2014\3rdParty\x64\VCRedist\2008SP1.6161\vcredist_x64.exe" /q
2014/12/1:21:43:19 Rebecca EPSMITH Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161 Succeeded
2014/12/1:21:43:19 Rebecca EPSMITH Download Play VCREDIST2008SP1X86_6161 http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/VCREDI...
2014/12/1:21:43:21 Rebecca EPSMITH Download Complete VCREDIST2008SP1X86_6161 http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/VCREDI...
2014/12/1:21:43:21 Rebecca EPSMITH Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161: "C:\Autodesk\WI\Autodesk Inventor 2014\3rdParty\x86\VCRedist\2008SP1.6161\vcredist_x86.exe" /q
2014/12/1:21:43:50 Rebecca EPSMITH Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161 Succeeded
2014/12/1:21:43:51 Rebecca EPSMITH Download Play VCREDIST2010SP1X64 http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/VCREDI...
2014/12/1:21:43:53 Rebecca EPSMITH Download Complete VCREDIST2010SP1X64 http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/VCREDI...
2014/12/1:21:43:53 Rebecca EPSMITH Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk Inventor 2014\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe" /q /norestart /log C:\Users\Rebecca\AppData\Local\Temp\vcredist_x64_2010sp1.log
2014/12/1:21:44:05 Rebecca EPSMITH Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2014/12/1:21:44:05 Rebecca EPSMITH Download Play VCREDIST2010SP1X86 http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/VCREDI...
2014/12/1:21:44:07 Rebecca EPSMITH Download Complete VCREDIST2010SP1X86 http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/VCREDI...
2014/12/1:21:44:07 Rebecca EPSMITH Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk Inventor 2014\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe" /q /norestart /log C:\Users\Rebecca\AppData\Local\Temp\vcredist_x86_2010sp1.log
2014/12/1:21:44:19 Rebecca EPSMITH Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2014/12/1:21:44:20 Rebecca EPSMITH Download Play CM http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/CM.tar...
2014/12/1:21:44:32 Rebecca EPSMITH Download Complete CM http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/CM.tar...
2014/12/1:21:44:32 Rebecca EPSMITH Installing Autodesk Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2014" SETUP_PACKAGECODE={8CB42675-1800-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161,;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Inventor 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/12/1:21:45:21 Rebecca EPSMITH Install Autodesk Material Library 2014 Succeeded
2014/12/1:21:45:23 Rebecca EPSMITH Download Play CMILB http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/CMILB....
2014/12/1:21:45:57 Rebecca EPSMITH Download Complete CMILB http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/CMILB....
2014/12/1:21:45:57 Rebecca EPSMITH Installing Autodesk Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2014" SETUP_PACKAGECODE={8CB42675-1800-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161,{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Inventor 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/12/1:21:46:29 Rebecca EPSMITH Install Autodesk Material Library 2014 - Base Image Library Succeeded
2014/12/1:21:46:30 Rebecca EPSMITH Download Skipped DIRECTX http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/DIRECT...
2014/12/1:21:46:30 Rebecca EPSMITH Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Inventor 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/12/1:21:46:37 Rebecca EPSMITH Install DirectX® Runtime Succeeded
2014/12/1:21:46:38 Rebecca EPSMITH Download Play CMILL http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/CMILL....
2014/12/1:21:47:37 Rebecca EPSMITH Download Aborted CMILL http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/CMILL....
2014/12/1:21:47:37 Rebecca EPSMITH Install Autodesk Material Library 2014 - Low Image Library Failed Download Failed, Installation aborted, Result=1603
2014/12/1:21:47:38 Rebecca EPSMITH Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/12/1:21:47:39 Rebecca EPSMITH PageOpen InstallCompleteDialog
2014/12/1:21:59:14 Rebecca EPSMITH === Setup ended ===
2014/12/1:22:00:02 Rebecca EPSMITH === Setup started on EPSMITH by Rebecca ===
2014/12/1:22:00:02 Rebecca EPSMITH Path_Length: 182
2014/12/1:22:00:02 Rebecca EPSMITH Current Directory C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_wi_en-US
2014/12/1:22:00:02 Rebecca EPSMITH Launch
2014/12/1:22:00:02 Rebecca EPSMITH CommandLine /url "http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/Autodesk_Inventor_2014_Eng_64bit_wi_en-US_Set... /SN 900-49854871 /PK 797F1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/12/1:22:00:02 Rebecca EPSMITH Current Directory C:\Users\Rebecca\AppData\Local\Temp\_AI70A5.tmp
2014/12/1:22:00:06 Rebecca EPSMITH === Setup ended ===
2014/12/1:22:00:04 Rebecca EPSMITH === Setup started on EPSMITH by Rebecca ===
2014/12/1:22:00:04 Rebecca EPSMITH Path_Length: 182
2014/12/1:22:00:04 Rebecca EPSMITH Current Directory C:\Users\Rebecca\AppData\Local\Temp\_AI70A5.tmp
2014/12/1:22:00:04 Rebecca EPSMITH Launch
2014/12/1:22:00:05 Rebecca EPSMITH Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/SETUP_...
2014/12/1:22:00:05 Rebecca EPSMITH Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Rebecca\AppData\Local\Temp\_AI70A5.tmp\Setup\InventorUI.dll
2014/12/1:22:00:05 Rebecca EPSMITH Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/12/1:22:00:06 Rebecca EPSMITH PageOpen LaunchDialog
2014/12/1:22:00:14 Rebecca EPSMITH Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2014/12/1:22:00:14 Rebecca EPSMITH Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2014/12/1:22:00:14 Rebecca EPSMITH Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message:
2014/12/1:22:00:39 Rebecca EPSMITH PageOpen LicenseDialog
2014/12/1:22:00:39 Rebecca EPSMITH PageOpen ProductInfoDialog
2014/12/1:22:00:39 Rebecca EPSMITH PageOpen InventorFlavorSelectionDialog
2014/12/1:22:00:39 Rebecca EPSMITH Inventorui==DefaultLanguage: en-us
2014/12/1:22:00:39 Rebecca EPSMITH Inventorui==InstallName: INVENTOR
2014/12/1:22:00:39 Rebecca EPSMITH Inventorui==ProductName: Autodesk Inventor 2014
2014/12/1:22:00:39 Rebecca EPSMITH Inventorui==DisplayName: Autodesk® Inventor® 2014
2014/12/1:22:00:39 Rebecca EPSMITH Inventorui==DeploymentName:
2014/12/1:22:00:39 Rebecca EPSMITH Inventorui==SetupTitle: Autodesk Inventor 2014
2014/12/1:22:00:39 Rebecca EPSMITH Inventorui==ConfigTransform:
2014/12/1:22:00:39 Rebecca EPSMITH Inventorui==ExeParams:
2014/12/1:22:00:39 Rebecca EPSMITH Inventorui==ProductCode: {7F4DD591-1864-0001-0000-7107D70F3DB4}
2014/12/1:22:00:39 Rebecca EPSMITH Inventorui==SupportLink:
2014/12/1:22:00:39 Rebecca EPSMITH Inventorui==InfotainmentLink:
2014/12/1:22:00:39 Rebecca EPSMITH Inventorui==MsiFileName: inventor.msi
2014/12/1:22:00:39 Rebecca EPSMITH Inventorui==AdminImageConfigName: Imgx64
2014/12/1:22:00:39 Rebecca EPSMITH Inventorui==AdminImageRoot:
2014/12/1:22:00:39 Rebecca EPSMITH Inventorui==GetBaseDeploymentName:
2014/12/1:22:00:39 Rebecca EPSMITH Inventorui==DeploymentLocation:
2014/12/1:22:00:39 Rebecca EPSMITH Inventorui==DocumentLink: http://autodesk.com/wikihelp-inventor-install-2014-enu
2014/12/1:22:00:39 Rebecca EPSMITH Inventorui==InstallDeploymentShortcut:
2014/12/1:22:00:39 Rebecca EPSMITH Inventorui==ModifyDeploymentShortcut:
2014/12/1:22:00:39 Rebecca EPSMITH Inventorui==SetupLockType: 2
2014/12/1:22:00:39 Rebecca EPSMITH Inventorui==SetupNetworkType: 1
2014/12/1:22:00:39 Rebecca EPSMITH Inventorui==SystemLocale: 1033
2014/12/1:22:00:39 Rebecca EPSMITH Inventorui==EvalMsiFilePath: C:\Users\Rebecca\AppData\Local\Temp\_AI70A5.tmp\SetupRes\eval.msi
2014/12/1:22:00:39 Rebecca EPSMITH Inventorui==EulaPath: C:\Autodesk\WI\Autodesk Inventor 2014\EULA
2014/12/1:22:00:39 Rebecca EPSMITH Inventorui==InstallLogPath: C:\Users\Rebecca\AppData\Local\Temp\Inventor2014Install.log
2014/12/1:22:00:39 Rebecca EPSMITH Inventorui==ConfigFile: C:\Users\Rebecca\AppData\Local\Temp\_AI70A5.tmp\Setup.ini
2014/12/1:22:00:39 Rebecca EPSMITH Inventorui==SetupPath: C:\Users\Rebecca\AppData\Local\Temp\_AI70A5.tmp\
2014/12/1:22:00:39 Rebecca EPSMITH Inventorui==NetworkLogPath:
2014/12/1:22:00:39 Rebecca EPSMITH Inventorui==SourceRoot: C:\Autodesk\WI\Autodesk Inventor 2014
2014/12/1:22:00:49 Rebecca EPSMITH Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2014/12/1:22:00:49 Rebecca EPSMITH PageOpen ProductSelectionDialog2
2014/12/1:22:01:08 Rebecca EPSMITH PageOpen FullProgressDialog
2014/12/1:22:01:09 Rebecca EPSMITH Download Skipped DIRECTX http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/DIRECT...
2014/12/1:22:01:09 Rebecca EPSMITH Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Inventor 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/12/1:22:01:15 Rebecca EPSMITH Install DirectX® Runtime Succeeded
2014/12/1:22:01:15 Rebecca EPSMITH Download Play CMILL http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/CMILL....
2014/12/1:22:02:16 Rebecca EPSMITH Download Aborted CMILL http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/CMILL....
2014/12/1:22:02:16 Rebecca EPSMITH Install Autodesk Material Library 2014 - Low Image Library Failed Download Failed, Installation aborted, Result=1603
2014/12/1:22:02:17 Rebecca EPSMITH Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
