Installation & Licensing
please provide activation code
2 REPLIES 2
299 Views, 2 Replies
dear sir
Please provide activation code of below reqest code
Serial Number: xxx-xxxxxxxx
Product Key: xxxxx
Request Code:
sunil tailor
Edited by
Discussion_Admin
2 REPLIES 2
AcadAdamLT
You should contact Autodesk support if you have a problem with activation, don't consult the forums about these things. The forums can't help you in this case.
Regards
Signature, sincerely... //Adam
AutoCad LT 2016
Give Kudos where credit is due, Mark "accepted as solution" if the post solved your question.
pendean
You'd better delete all that info ASAP, you just gave away your purchased product info to the world of hackers. Way to go.
Go here instead: https://register.autodesk.com/
and read this: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17971157&linkID=9240617
Administrator Productivity
