Hi
I need help. I have installed Autocad and when I start it, I get, a message
Can not find procedure entry adaress K32EnumProcesses in DLL file KERNEL32.DLL
How do you solve it. thanks in advance
Rather than buying a new computer, see if you can purchase Win 7 or Win 8.1. Probably cheaper. And yes, you can download AutoCAD again, as many times as you need to. If the program was purchased, you have purchased the rights to run the software and can download and save the installation program once and reinstall when needed. If you are using the EDU (free educational) version, you may need to do the download and install in a single step. In both cases you will need to re-activate the program once installed.
