Installation & Licensing
Please help, I cant open my 3ds max design 2012
8 REPLIES 8
Message 1 of 9
101051490
7979 Views, 8 Replies
I download the student 3ds Max Design 2012
mine is vista and choose Autodesk 3ds Max Design 2012 32-bit - English
When I run it, it stop with loading plug-in: C:\ Program Files\Autodesk\3ds Max Design 2012\stdplugs\HSDS.dlm
After I choose Change Graphics Mode- English, it still the same
Can anybody help? thx a lot, very urgent :'(
8 REPLIES 8
Message 2 of 9
byron.morales
in reply to: 101051490
Please test resetting the HSDS.dlm configuration file.
1. Close 3ds Max Design 2012.
2. Browse to the following local user application preferences directory-
Windows VISTA / Windows 7
C:\Users\YOUR_USER_NAME\AppData\Local\Autodesk\3ds​MaxDesign\2010 - 32bit\enu\plugcfg
3. Rename the HSDS.dlm configuration file in this direcrtory to HSDSdlm_old
4. Restart 3ds Max Design 2012, new user application preference file will be created on startup.
I hope that the above information is useful.
If renaming the HSDS.dlm to hsdsdlm_old does not help. You can also copy the hsds.dlm from another working machine and see if that works.
Byron Morales
Product Support | Up and Ready Blog | If my reply was helpful, please Kudo or Accept as Solution. :smileywink:
Byron M.
Message 3 of 9
in reply to: byron.morales
I am having the same problem with 3ds Max 2012 64-bit. When starting it up, it hangs on HSDS.dlm... I went into local app data folder and into the plugcfg folder but theres no HSDS.dlm file there.
Message 4 of 9
Ditto. Same problem. Not seeing the noted file in my plgcfg folder.
Message 5 of 9
Thank u so much!
I was having the same problem and I renamed the HSDS file and it worked!
Thank you. Days of trying to find solutions finally came to an end.
People... if you are having the same problem... try this! 🙂
Message 6 of 9
gentlestev
Help me friends. I bought 3dsmax design 2012. When i start it. It loads all the plugins perfectly but keeps still at 'starting 3dsmax......' without bringing up the user interface and no error even when i left it for almost 10hours i wont come up. Hlp me plzzzzzzzzzzz. Here or email stevenonyeje@gmail.com
Message 7 of 9
in reply to: gentlestev
I had the same problem as gentlestev and it was solved when I chose Change Graphics Mode>English>Open GL
Do give it a shot and lemme know if it works out!
Message 8 of 9
zev.richards
In case any one cannot find the HSDS.dlm file in appdata directory stated above, I found mine in C:\Program Files\Autodesk\3ds Max 2012\stdplugs and changed it to HSDS.dlm.off. Max then loaded up fine. I hope I won't need it later.
Message 9 of 9
BMW0939
hi go to C:\Program Files\Autodesk\3ds Max 2014\stdplugs  (your software folder location) . search for hsds.dlm and rename it to HSDSdlm_old ( the .dlm must be remove)
start your software.
be like the water my friend
Administrator Productivity
