I have tried with no sucess install 2014 so I tried 2013 neither will install from deployment. I get the same log for both versions. I was currently using 2011, so I installed 2012 and it works fine. But I need to get 2014 working. Please help.
Install Autodesk AutoCAD Civil 3D 2014 Product Specific Pack Failed Installation aborted, Result=1603
Looks like it is failing on installing an addional product pack. Make sure you do a custom install and do not add any additional files or service packs.
For example, see this:
Do i also uncheck sub components. Then redoploy when autocad works. Which features do you recommend to uncheck? I unchecked autodesk seek, autodesk 360.
I'd start as basic as you think you need. At least get a base install. Then you can add additional features later.
