I am using AutoCAD 2013 on a Windows 7 Ultimate machine. In planning a motherboard change, how do I insure that I will not need to reactivate my license?
Not planning to alter the hard drive in any way, except to re-authorize Windows if necessary.
Solved by TravisNave. Go to Solution.
You cannot ensure that it won't break. Changing your mobo will absolutely 100% invalidate your license. You will have to delete the activation files under C:\ProgramData\Flexnet\adsk* once replaced and then reactivate the software. The LTU won't work for you in this scenario.
Good Luck!
