Does anyone know if it's possible to have a command line / batch file / schedule task to run the LMTOOLS "Perform Status Enquiry" periodically and spool the results or send it to a text file? we're trying to determine if we need to purchase more licenses - and would like me to determine how many of our concurrent licenses we're using on average. i could look through the logs but they don't clearly show how many are in use at a given time. thanks in advance.
Solved by TravisNave. Go to Solution.
Yes, you can do this. You can just use the command line interface to pipe it to a .txt file. Instructions are in the user documentation.
Also what you can do is create a report log file with an adskflex.opt options file and then use a program like JTB Flex Report to analyze the data.
Travis, a small correction. JTB FlexReport cannot read the report logs (.RL). It takes snapshots from lmutil.exe and denials from the FlexNet debug log.
Continue with Travis's suggestion, you can create a report log file(.rl) with an adskflex.opt options file,then use SAMReport to analyze the data.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
