Installation & Licensing
out of disk space Revit 2013
4 REPLIES 4
2619 Views, 4 Replies
 I downloaded Autodesk Revit 2013 when I trying to install there is a message: out of disk space. In that case my hardisk on Part C still more space (19 GB,). System requirement was 5Gb free disc space require.  I can´t install Revit now.
4 REPLIES 4
TravisNave
You need lots of space for the installation temp files and downloading of the materials library.  Probably should have about 40GB free for installation.
Autodesk Forums:
emily.xu
I think this article can give you an explaination why you out of disk space:http://upandready.typepad.com/up_and_ready/2012/06/downloading-software-you-need-at-least-triple-the...
So I would suggest you to move your download and extracted files to D disk, and empty the temp folder, then try to install.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Emily Xu
Product Support
khsaeid
unfortunatley i have this problem too... revit structure 2013 require 79.8 GB disk space ..... please help me solving this problem
Sæmorr
Administrator Productivity
