Hi --
I'm trying to install 3DSMax on a Mac using a new copy of Parallels to run it under a Windowd XP virtual machine. When I put the disk in and double click on the icon I get the following error:
Ordinal 278 could not be located in the dynamic link library msi.dll
This is a new installation, no Autodesk products have been previously installed. What can I do to make this work?
Roland
I tried deleting the contents of %TEMP% and restarting in Diagnostic mode using MSCONFIG, but neither helps.
Please advise as I need to get 3DS Max installed asap.
Thanks a lot
