Installation & Licensing
Options File - Specify Maximum Licenses for All Features
1 REPLY 1
jwilliams
937 Views, 1 Reply
Does anyone know how to set a maximum number of license for all features in the options file?  I am aware of the syntax to set the maximum for a specific feature (like: MAX 2 85788BDSADV_F GROUP Project1), but my problem is we have both Premium and Ultimate Building Design Suites.  So, I would like one project to not be able to access more than 4 licenses of any type.  I don't care if they have 1 Premium and 3 Utlimates, or just 4 Premiums.  What I currently have written is:
MAX 2 85787BDSPRM_F GROUP Project1
So this limits them to 2 Premium Suites and 2 Ultimate Suites.  But lets say another project has all the Ultimate licenses tied up, then Project 1 is limited to only 2 licenses, when they should be able to get 4.
What I'm looking for is something like this:
MAXALL 4 GROUP Project1      or     MAX 4 AllFeatures GROUP Project1
Any thoughts?
Joe Williams
Rogers-O'Brien Construction
Revit Gunslinger
1 REPLY 1
TravisNave
in reply to: jwilliams
Well, you could do some combination testing.  Along with your MAX 2 of each suite, you could also RESERVE 2 for each suite on the group.  That would immediately check out 4 licenses max to that project.  Four people could access four licenses but no more.  And other projects could access the remainder except for the 2 reserves.  That might get you by.  Don't forget to use the GROUPCASEINSENSITIVE ON.  See my Options file link for a list of all the available compatible options to use.
Autodesk Forums:
Administrator Productivity
