Installation & Licensing
Option File Manual
1 REPLY 1
charlv
424 Views, 1 Reply
Option File Manual
Hi all,
Can anyone point me to a site/url to learn more about the Flex LM adskflex.opt OPTIONS File. Browsing through the discussion groups I have come across setting up either groups, host groups, ip adress groups and then applying RESERVE and MAX statements to these groups. What are the others option?
thanks
Charl
1 REPLY 1
TravisNave
in reply to: charlv
It's in the DOCS folder of your installed NLM.
Or you can view it here:
http://www.macrovision.com/pdfs/flexnet_licensing_end_user_guide.pdf
Autodesk Forums:
Administrator Productivity
