Installation & Licensing
232 Views, 1 Reply
OPT File
I wanted to use the option reserve in order to reserve 5 licenses with Internet type.
The problem is that I have 3 ranges of IP addresses and I did not want to reserve 5 licenses for every range.
RESERVE 1 f1 INTERNET
range 1 192.22.92.*
range 2 192.22.93.*
range 3 192.22.95.*
how I can make?
Thank
1 REPLY 1
TravisNave
Unfortunately, the options file is not specific enough for you to do exactly what you want to do in these ranges, since your wild card in the 3rd octet would get you more of the subnet than you want.
You may just have to set up a group and add all of the users or host PCs to it instead.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
