I just got done installing Flow Design and tried opening the application and all that comes up is the loading screen. There is no loading status bar or any indication of what is happening. Anyone else had this problem?
Solved by hartogj. Go to Solution.
If you are starting the standalone version of Flow Design and it is not appearing on screen, I'd first check the graphics card support. Do you know if your driver supports OpenGL 3.0 (or higher)?
Beyond that, be sure you are also on a supported OS and installed with admin rights.
