Please issue an activation code for the attached serial no.
regards gangadharan kuniyil
Solved by DarrenP. Go to Solution.
DarrenP
Hi Gangadharan,
I removed the attached file that contains your Serial # for security reasons.
Note that the Serial Number provided has been Upgraded to its 2013 version. Would you continue using the 2012 or the2013 version? If you prefer the 2013, use the download links below. After download, please send me a Private Message (click on my joane.bonghanoy profile name and then “Send this user a private message”) with your Request Code.
Download Links :
- Autodesk AutoCAD 2013 - 32 bit
- Autodesk AutoCAD 2013 - 64 bit
If you prefer to use 2012, just reply back with the Request Code, however note that you can only use one version.
