Installation & Licensing
ntpclient errors on the license server
8 REPLIES 8
Message 1 of 9
893 Views, 8 Replies
ntpclient errors on the license server are preventing licenses from being available.
I created a support call and their solution is to totally rebuild the license server.
This can't be option one....ideas?
Tim
8 REPLIES 8
Message 2 of 9
TravisNave
I doubt it.  Though you can get a 0.0.0 error at the client if the time on the client and the time on the server do not have the same time.  You might check to see what the difference is and correct it.
I'd at least start at the CMD prompt and run W32TM /RESYNC to see if the time corrects itself.
You might also set the NLM up as a time server and sync the clients to it.  That way, even if they are both wrong it should still work.  I've done that before.  🙂
What error are the clients getting exactly?
Autodesk Forums:
Message 3 of 9
in reply to: TravisNave
I'm assuming that the client error is a standard 'I can't find a license so I'm not going to load' error from Acad. Did not see it. The first time it happened I received a few calls from various locations. It's a GNUL server.
Message 4 of 9
TravisNave
Sounds good.  It could also be a latency issue if they are accessing over a WAN.  Might increase the timeout using the FLEXLM_TIMEOUT variable listed here:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=7574782&linkID=9240617
Have them get you the error next time as it is helpful.
Autodesk Forums:
Message 5 of 9
As a standard, we have FLEXLM_TIMEOUT set to 1mil..but I will make sure that this user has that var set...could have been missed.
Thanks...
Message 6 of 9
TravisNave
Looks like you have a firm grasp on the NLM workings then.
Assuming  your NLM is actually working, you could also check to see if the ports work by testing them in Internet Explorer (only):
http://servername:27000
http://servername:2080
If a connection is being made, then both ports should yield a result similar to the following:
Wê-60Wê-60Wê-60Wê-60Wê-60
If not, then it could be something else blocking it.  It's a quick verification.
Autodesk Forums:
Message 7 of 9
both ports echo clean
Message 8 of 9
but...do these need to echo clean on the server too?
Message 9 of 9
TravisNave
It would only need to if the NLM wasn't starting or if you had an ADMS server running Vault and the clients couldn't connect to their Vaults.
Autodesk Forums:
Administrator Productivity
