I am new to AutoCAD I have it for school i created 2 drawings and everything was fine but know evertime i try to open the program it freezes and wont respond to anything i have to use my task manager to close it down. Can someone help me i have projects due thanks for your time
Did you do the clean uninstall steps for AutoCAD and replaced with a clean reinstall? Also, have you applied any Service Packs/Hotfixes for AutoCAD to get it up to date. These can be found here... http://knowledge.autodesk.com/support/autocad/downloads#?cg=Downloads&p=AutoCAD&doctype=Service%20Pa...
If you are using AutoCAD 2015 (for example), you could try right clicking on the AutoCAD shortcut, go to "Properties" and where it says "Target" add the following to the path...
"C:\Program Files\Autodesk\AutoCAD 2015\acad.exe" /product ACAD /language "en-US" /p "Test"
Select "Ok" and then open AutoCAD again, is that any better? What this should have done is opened AutoCAD with a brand new default AutoCAD profile that hasn't been created before.
Hello. It things were fine, and then were not fine, and you uninstalled and reinstalled and STILL are having the issue- you did not uninstall and remove everything. You missed something. Something on the system changed, that may not be the program and could always be the OS.
Pretty much ALL programs leave something behind. In this case, a regular uninstall and reinstall did not do it so that wasn’t the problem.
Did you “reset to defaults” yet?
Uninstall and search your c:\ drive for “AutoCAD”. You will find folders left behind. Especially in the USERS/ Roaming and Local folders. Remove that stuff.
Reset the licensing by deleting the adskflex tsf.data file:
Windows XP:
Documents and Settings\All Users\Application Data\FLEXnet
Vista/Windows 7:
C:\ProgramData\FLEXnet
Uninstall the Collateral, Non-Autodesk programs that are needed. The Microsoft C++ redistrinutables, and the Microsoft NET.
Now reinstall. At this stage you probably have good install to test.
If I were still having issues at this stage, I would update the graphics card drivers and check the Windows Event log- this culd tell you what is occurring.
Thank you for taking part in our community!
Windows XP:
Vista/Windows 7:
If I were still having issues at this stage, I would update the graphics card drivers and check the Windows Event log- this could tell you what is occurring.
