Installation & Licensing
Not installed 3ds Max Design 2014
7 REPLIES 7
Message 1 of 8
421 Views, 7 Replies
Я попытался установить 3ds Max Design 2014 для образования. Когда "Общий прогресс" показал 8 из 13 оставшихся, установка была прервана и диалоговое окно: "1: 5 2: adlmPITSetProductInformation удалось 3:. 26". Я нажал на кнопку "OK", то установка будет продолжена, но по завершении, ничего устанавливать.
Пожалуйста скажите мне, как я могу решить эту проблему.
7 REPLIES 7
Message 2 of 8
TravisNave
Message 3 of 8
in reply to: TravisNave
Thank you very much! Hope this helps.
Message 4 of 8
Hello, TravisNave. I could not solve my problem. I have a folder is missing "AdLM". So I can not change its properties or delete the file 'ProductInformation.pit'. But the reason is not in hidden folders. Hidden files are also displayed from the moment the first time I tried to reinstall 3ds Max Design 2014.
Reading the forums did not help to find a solution.
I would be grateful for your help.
Message 5 of 8
TravisNave
See if you can actually put the path in your address bar to make sure it does not exist:
C:\ProgramData\Autodesk\Adlm
Thanks.
Autodesk Forums:
Message 6 of 8
Travisnave, I'm glad that you do not leave attempts to help me. But the computer also could not find this location.
Message 7 of 8
I put the path in the address bar and there was an inscription: "Can not find" C:\ProgramData\Autodesk\AdLM ". Verify that the written word for search and try again"
Message 8 of 8
TravisNave
You might try to reinstall as administrator and then launch it as
administrator. Turn off UAC and antivirus. It might not have permission to
create that folder.
Autodesk Forums:
Administrator Productivity
