Our company has three networklicence (redundant) servers.
One of our cadstation has a startup problem.
From one day on the other it won't start anymore!
It is used by a colleague with only user rights on the cadstation.
For three months it has worked fine.
There are has been no changes of software only Microsoft's updates for
XP servicepack 3. 3GB 2.8GHz 4 x core
On the FlexLM (v11.5.0.0) log you can see the account login 2x OUT and 2x IN.
There are no messages on the cadstation or on the eventlog.
I have tried Autocad2010 "repair" "re-install" No result.
A have changed the .lic path in .lic.old so the Acad-session start and ask
for the netwerklicence server.
When it find that server it stops immediate.
There are no restrictions in the adsflex.opt file for this workstation.
Acad opens a tcp-port on 1060 to the server.
Is there a possibility to debug this problem?
How can i find a solution for this problem?
Thanks in advance
Dolf
Solved by hashim.mundol. Go to Solution.
Issue could be related to cascadeinfo.cas file
Fix is to rename/delete and start the program details here.
http://usa.autodesk.com/getdoc/id=TS13894457
To further troubleshoot on client side you can try the following
http://usa.autodesk.com/getdoc/id=TS14092874
Thank you for your answer.
It was the cascadeinfo.cas.
Such a small file can make a big difference.
Dolf
