It pops up to update serial number and product key. No sign in option to import the license I exported.
AutoCAD Infrastructure Design Suite 2014 Premium.
Anybody have a way around this, or a way I can view the license I exported?
I have the same problem.
I'm trying to export a Maya 2014 license from a PC + Win 7 Pro (no problem concerning to this) and to import it to a MacbookPro + OS X 10.9.2. In the process, when I click on Sign in button to access to the Log in window, nothing happens.
I would be very grateful for some help. Thanks in advance.
Finally, I was able to solve the problem through Autodesk Customer Support.
I followed their instructions of uninstall Maya 2014 and installing Maya 2014 SP4 from the following link...
However, there was a new problem... when running License Transfer Utility(English) on Mac, it was required to run an app through a path with a folder called "R7", that in the new installation is called "R8". I have copied/pasted folder "R8" in the same place and renamed "R7". This solved the problem of the path and I was able to launch License Transfer Utility and do the license importation without any additional problem 😉
