So, im running the nlm stuff on a mac mini with 10.8.4
I have a subscription so i get to upgrade my 2014 to 2015, got a new .lic for the server and downloaded the manditory 11.12 ipv4 nlm tools
installed as suggested, ran
./lmgrd -c /path/to/lic.lic
to start up the server, and got the new console/log output but no obvious errors or problems.
I can launch maya '14 and '15 locally on the server by giving it a .lic with localhost specified as the server, but no other computer can check out a lic.
on every other machine running either osx or win7 i get a [0.0.0] error and the message...
"License was not obtained Tried Maya 2014 (657F1 2014.0.0.F), error 20 License method: environment variable MAYA_LICENSE_METHOD='network' Product choice: environment variable MAYA_LICENSE='unlimited' License file override: environment variable MAYA_ALT_EN is not set "
Solved by peter_varnish. Go to Solution.
I figured it out...
i gave it a static port in the .lic on the server of 27003 and now it seems to work fine.
Thanks for nothing! haha jk... hope this helps somebody else.
Thanks for the update. Honestly there's not a lot who run the NLM on a Mac. So this probably will help someone.
