We use Kixtart (kixtart.org) during the logon script to import REG files
that are pieces of the exported profiles. Changes are made to files in a
central folder on a network share, so the users see them the next time they
login. This way, everytime the user logs in again, they are set back to a
standard. Pathing, settings, whatever. We also repoint the default menu to a
custom one on the network and let a MNL file deal with the inside autocad
issues. Single point of control.
Whatever can be exported in a ARG can be imported into the same profiles in
the registry, but you will have to write some kixscript to deal with the way
autocad profile ARG paths are abbreviated paths that go into user profile
directories. Autodesk uses a "non-registry-compliant" syntax to refer to
these directories. The ARG will show the "variable" name for the path, while
the same item in the registry will be expanded. You cannot make a single REG
file apply to all users for these paths, unless you move the user profile
directories back to the "acad" directory.
