Installation & Licensing
CTHSSSoftwareLicensing
222 Views, 1 Reply
new server setup
I am in the process of setting up a new server with the autocad license software.  The new server has several NIC cards connected and when I tried to use the license file I download, I get the following error:
SERVER line says d4bed9b29abe, hostid is "d4bed9b29aad d4bed9b29ab3"
Can you assist with this issue?
1 REPLY 1
Run ipconfig /all. Select the one that corresponds to a physical network adapter. View the Description field above each physical address. If there is more than one physical network adapter, it does not matter which one you use. Devices such as VPN adapters, PPP adapters, and modems are not valid.
Jimmy Bergmark
JTB World - Software development and consulting for CAD and license usage reports
https://jtbworld.com
Administrator Productivity
