Installation & Licensing
TravisNave
Message 11 of 21 (1,851 Views)
Re: New install of 2012 Entertainment Creation Suite - missing LiteHtml.dll?
01-25-2013 07:48 AM in reply to: abrumathew007
Try the solutions posted above (now marked) or try the one listed at towards the end of this thread:
http://forums.autodesk.com/t5/Installation-Licensing/SETUP-EXE-ENTRY-POINT-NOT-FOUND/td-p/3107508/pa...
You can search other areas of the site for this issue as well:
http://forums.autodesk.com/t5/forums/searchpage/tab/message?filter=location&location=forum-board%3A2...
For additional information, please consider using Search to assist in your resolution:
Search Autodesk.com
Search Autodesk Discussion Groups
Search Up and Ready Blog
Search Autodesk WikiHelp
New Member
paulo_wii
Message 12 of 21 (1,606 Views)
05-29-2013 08:00 PM in reply to: jfrost5
Nice! You give me the solution! So I create this (Portuguese PT-BR):
Em caso de erro ao clicar no arquivo de instalação: Setup.exe, indicando a mensagem:
"The program can't start because [NOME DO ARQUIVO].dll is missing form your computer.Try reinstalling the program to fix this problem."
deve-se copiar todas os arquivos .DLL contigos na pasta \Setup para dentro do diretório: C:\Windows\SysWOW64\
All we have to do is to copy all the DLL Files in the Setup folder inside the program folder into the Folder indicated by you:  C:\Windows\SysWOW64\ and the problem goes out!
Tks !
Active Contributor
jeffjensen
Message 13 of 21 (1,227 Views)
06-19-2013 05:09 PM in reply to: MayaWannabe
This solution did not work for me. I'm trying to install Autodesk product (Revit 2014 and Civil 3D 2014) downloaded from students.autodesk.com. I'm trying to install on a Windows 8 x64 laptop. Here is the steps I did, which doesn't work, still get the litehtml.dll error
1. login with administrator account
2. download Autodesk_Revit_2014_English_Win_32-64bit_dlm.sfx.exe
3. run the exe which does a unzip/extract to c:\autodesk
4. I get the missing litehtml.dll error
5. copy using the command prompt:
copy C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_dlm\setup\*.dll C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_dlm\
copy C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_dlm\en-us\*.dll to
6. run C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_dlm\setup.exe
7. Again I get the missing litehtml.dll error but the install windows freezes.
I also attempted the other suggestion in this thread about the regedit but I couldn't find the setting in Windows 8.
Any ideas how to install Autodesk products on Windows 8. Note, I'm getting similar errors with another Autodesk product, Civil 3D.
thanks,
Jeff Jensen
Member
jakub.kolar
Message 14 of 21 (1,146 Views)
06-24-2013 09:09 AM in reply to: jeffjensen
i am having same problem with Inventor 2013 in windows 8 (x 64 ) and also notebook
Trying to solve for hours ..
Active Contributor
jeffjensen
Message 15 of 21 (1,136 Views)
06-24-2013 09:43 AM in reply to: jakub.kolar
I was able to install Civil 3D 2014, Revit 2014 and InfraWorks 2014 when I
did the following
1. clean install of Windows 8 enterprise - 64bit
2. installed Autodesk software
3. then ran windows updates. My guess is the windows update is either in
the process of updating (might need a reboot) and that is the reason why we
cannot install Autodesk software. Note, this is just a guess. Yes, I wasted
many hours on this issue too.
thanks,
Jeff Jensen
New Member
esi729
Message 16 of 21 (914 Views)
07-08-2013 02:23 AM in reply to: jeff.laing
i have this problem with autodesk 3ds max 2012 in win8-64. can you help me?
New Member
esi729
Message 17 of 21 (914 Views)
07-08-2013 02:36 AM in reply to: abrumathew007
copy all .DLL files from setup folder to C:\Windows\SysWOW64
TravisNave
Message 18 of 21 (910 Views)
07-08-2013 05:16 AM in reply to: esi729
Keep in mind though that 2012 is not supported in Win8.
New Member
Daaaave
Message 19 of 21 (715 Views)
07-19-2013 04:14 PM in reply to: TravisNave
I've been having the same problems since I formatted my laptop. I did find a solution eventually thanks to the people on here so just incase anyone is still having trouble
I manged to install all my 3ds Max downloads by running them in administrator mode. For Maya and Motionbuilder, I had to copy the DLLs from the 3ds Max setup folder to the SysWOW64 folder in Windows Directory. I'm not sure if it had anything to do with running Windows8 but given that It previously ran Max 2011,12, 13 and 14 fine, it is a little odd that I had this problem this time.
All the best
Dave
New Member
darryl.mckillop
Message 20 of 21 (644 Views)
07-25-2013 06:37 PM in reply to: Daaaave
I can concur this is what I had to do as well with 3DS Max 2014 x64 on WIN 8. Copy all *.dll files from Autodesk setup directory and paste them into C:\Windows\SysWOW64 directory. Viola!
