I have a new computer with Windows 7.
I have installed Autocad 2007, I got a key and I could open AutoCAD once, executing it like and Administratr. I could work but not save anything.
Today I tried to open it as an administrator but I could not open it and I get this message:
Nom d’événement de problème: APPCRASH
Nom de l’application: acad.exe
Version de l’application: 23.0.54.0
Horodatage de l’application: 440acd95
Nom du module par défaut: ntdll.dll
Version du module par défaut: 6.1.7600.16385
Horodateur du module par défaut: 4a5bdb3b
Code de l’exception: c0000005
Décalage de l’exception: 00022333
Version du système: 6.1.7600.2.0.0.768.3
Identificateur de paramètres régionaux: 3084
Information supplémentaire n° 1: 4c0d
Information supplémentaire n° 2: 4c0d4d78887f76d971d5d00f1f20a433
Information supplémentaire n° 3: 4c0d
Information supplémentaire n° 4: 4c0d4d78887f76d971d5d00f1f20a433
What can I do
Thand you
Ginette
Solved by TravisNave. Go to Solution.
AutoCAD 2007 is not supported on Windows 7. Only Autodesk products 2010 and newer are supported to be installed on Windows 7. You can download and install the Windows XP Virtual PC from Microsoft, however, and install it on there. Otherwise, you will need to install on a Windows XP machine.
