Installation & Licensing
New computer cannot open Autocad
1 REPLY 1
858 Views, 1 Reply
I have a new computer with Windows 7.
I have installed Autocad 2007, I got a key and I could open AutoCAD once, executing it like and Administratr.  I could work but not save anything.
Today I tried to open it as an administrator  but I could not open it and I get this message:
  Nom d’événement de problème:      APPCRASH
  Nom de l’application:                        acad.exe
  Version de l’application:                    23.0.54.0
  Horodatage de l’application:            440acd95
  Nom du module par défaut:             ntdll.dll
  Version du module par défaut:         6.1.7600.16385
  Horodateur du module par défaut:  4a5bdb3b
  Code de l’exception:                          c0000005
  Décalage de l’exception:                   00022333
  Version du système:                           6.1.7600.2.0.0.768.3
  Identificateur de paramètres régionaux:        3084
  Information supplémentaire n° 1:    4c0d
  Information supplémentaire n° 2:    4c0d4d78887f76d971d5d00f1f20a433
  Information supplémentaire n° 3:    4c0d
  Information supplémentaire n° 4:    4c0d4d78887f76d971d5d00f1f20a433
What can I do
Thand you
Ginette
1 REPLY 1
TravisNave
AutoCAD 2007 is not supported on Windows 7.  Only Autodesk products 2010 and newer are supported to be installed on Windows 7.  You can download and install the Windows XP Virtual PC from Microsoft, however, and install it on there.  Otherwise, you will need to install on a Windows XP machine.
Autodesk Forums:
Administrator Productivity
