I have replaced my Laptop with a new one still running Windows 7. I have tried to reinstall my autocadLT 2012 and continue to have it fail.
Here is the Log:
2015/1/15:12:38:07 Robertc BUVC2BFA6 === Setup started on BUVC2BFA6 by Robertc ===
2015/1/15:12:38:07 Robertc BUVC2BFA6 Launch
2015/1/15:12:38:30 Robertc BUVC2BFA6 === Setup ended ===
2015/1/15:12:38:08 Robertc BUVC2BFA6 === Setup started on BUVC2BFA6 by Robertc ===
2015/1/15:12:38:08 Robertc BUVC2BFA6 Launch
2015/1/15:12:38:30 Robertc BUVC2BFA6 PageOpen LaunchDialog
2015/1/15:12:38:41 Robertc BUVC2BFA6 PageOpen LicenseDialog
2015/1/15:12:38:46 Robertc BUVC2BFA6 PageOpen ProductInfoDialog
2015/1/15:12:39:41 Robertc BUVC2BFA6 PageOpen ProductSelectionDialog2
2015/1/15:12:39:43 Robertc BUVC2BFA6 PageOpen FullProgressDialog
2015/1/15:12:39:44 Robertc BUVC2BFA6 Installing .NET Framework Runtime 4.0: D:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2015/1/15:12:40:06 Robertc BUVC2BFA6
Any suggestions?
Chuckrts@gmail.com
Solved by TravisNave. Go to Solution.
Might post the whole log. That one doesn't seem complete.
Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603
Your product is failing to install because the prerequiste program required by the installer is failing prior to the installation of your Autodesk software.
If the prerequisite program already exists on your computer, it is likely newer than the one the Autodesk installer is attempting to install. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
If the prerequisite is not already installed and installation still fails, then you may need to make an advanced edit to the setup.ini file to ignore the error. Please make sure you manually install the prerequisite file from Microsoft and then modify the setup.ini file accordingly.
For more information on this process, please see my KB article here:
http://forums.autodesk.com/t5/Installation-Licensing/Install-NET-Framework-Language-Pack-Failed-Inst...
@chuckrts wrote:
I just want to instal; the 2012 version and then will probably upgrade.
Chuck
You don't need a previous version installed to upgrade. You can just install the latest version that you own.
