Hi All,
This is the first time I have tried to install a product suite and I can't get going, so be gentle!!
So, I have downloaded all the required files to a server.
I then extract the first file to my C: drive but I get the error message "This installation package cannot be installed by the Windows Installer Servce. You must install a Windows service pack that contains a newer version of the Windows Installer service"
Is there something I am doing wrong or do I need this service pack?
Or do you extract all filles to C: drive first then hit the setup exe?
Ta
PC Spec is as follows:
Windows XP Professional x64 Edition Service Pack 2 (build 3790)
Install Language: English (United States)
System Locale: English (United Kingdom)
Board: Hewlett-Packard 3031h
Serial Number: CZC9480N7X
Bus Clock: 800 megahertz
BIOS: Hewlett-Packard 786G1 v01.16 03/05/2009
2.60 gigahertz Intel Pentium Dual-Core
64 kilobyte primary memory cache
2048 kilobyte secondary memory cache
64-bit ready
Multi-core (2 total)
Not hyper-threaded
8060 Megabytes Usable Installed Memory
250.05 Gigabytes Usable Hard Drive Capacity
80.37 Gigabytes Hard Drive Free Space
Solved by DarrenP. Go to Solution.
if this is 2014 you can't install on XP unless you hack the setup.ini
system requirements: http://usa.autodesk.com/adsk/servlet/pc/item?siteID=123112&id=16490792
DarrenP
